Pt1000 not showing correct temperature
Though I set thermistor to Pt1000 using this command: M308 S1 P"e0temp" Y"pt1000", what i can see is too much high temperature, which is, about 360 celcius. What should i do?
@webcur2010 are you certain that the sensor you have is a PT1000? If you have a multimeter, measure its resistance at room temperature.
Which Duet and firmware version are you using?
@dc42 Solved by adding R2200 at last in that command!
