    Error: M950: exactly one of FHJPSR must be given
    Duet Web Control
    • CorvoDewittV2undefined
      CorvoDewittV2
      I am getting an error when I run this config, and I am not sure why. I added a 2 pin fan and the last 3 lines of code on the config file and it stared to throw the Error: M950: exactly one of FHJPSR must be given. Any idea what I set up wrong?
      config.g
      infiniteloopundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • infiniteloopundefined
        infiniteloop @CorvoDewittV2
        @CorvoDewittV2 said in Error: M950: exactly one of FHJPSR must be given:
        Yes: when you define tool 0 with M563, you assign two fans (F0:1) to it, but due to your changes to the config, fan "Nevermore" is not yet defined at that stage. See M950: Create heater, fan, spindle or GPIO/servo pin, especially the topic Order dependency.
        CorvoDewittV2undefined 1 Reply Last reply Reply Quote 1
          CorvoDewittV2 @infiniteloop
          @infiniteloop Ah! Got it, thanks!!
            dc42 administrators @CorvoDewittV2
            config.g
            I think it's this line:
            M950 D1 C"spi.cs0+spi.cs2"
            The M950 D parameter is only supported in Duet 3 MB6HC boards, and only in firmware 3.4.0 and later.
