    Can't establish wifi connection in new installation
    Firmware installation
    1.1k
    • 1d1undefined
      1d1
      I can't seem to get a network established to a new 1.19 duet wifi board for my cartesian printer. I can get to the point of "no known network; wifi module is idle", M503 gives me a test config. I've run the configurator and placed it on the duet sd card. Finally, this is a second Duet on a second printer, so I need to establish separate networks. I've spent way too much time and energy getting nowhere. It isn't the fault of the Duet, I'm sure, but I don't know where/what/how to proceed from here.
      • KeeganBundefined
        KeeganB
        are you communicating with the duet via Pronterface over USB?
        Do this.
        M588 S"*"
        M552 S0
        wait about 30 sec or so, or until Pronterface reports the wifi module is idle
        M587 S"NetworkSSID" P"password"
        M552 S1
        Note that the SSID and password will be case sensitive and Pronterface will convert them to all caps unless you tell it not to by including apostrophes in the appropriate locations.
        https://duet3d.com/wiki/G-code
        I think David prefers doing this with a Macro, but I have done it so many times now, i prefer sending commands via USB.
        Artemis
        Rostock Max v2
        Orion
        • 1d1undefined
          1d1
          OK. Done all that but I'm missing a step or two apparently - What is my SSID and password ="reprap"? I've been using 192.168.1.1
          Thanks, Keegan!
            The SSID is the name of the WiFi network you want the Duet to connect to, and the password is the password for connecting to that wifi network.
            • KeeganBundefined
              KeeganB
              You SSID is the name of your wireless network. The password is your password for that wireless network. These are both case sensitive and need to be typed in correctly per the wiki link I provided because Pronterface converts all text to CAPS unless you tell it not to.
              Artemis
              Rostock Max v2
              Orion
              • 1d1undefined
                1d1
                OK! Connected.
                Thanks to you both!
