    First time compile issues
    Firmware developers
    1.3k
    • jpsantosundefined
      jpsantos
      Hi everyone, I'm having trouble getting past the stage of building the project for the first time, on a Windows based Eclipse.
      I'm working with latest version of the master branch of dc42/RepRapFirmware and dc42/CoreNG, as of this morning in fact.
      I'm building SAM4E of CoreNG and DuetEthernet of RepRapfirmware.
      After successfully building the CoreNG archive my g++ cross compiler bombs out as per below.
      Also, it doesn't seem to be referencing the libCoreNG.a lib or am I wrong or shouldn't it?
      [[language]]
      10:21:59 **** Build of configuration DuetEthernet for project RepRapFirmware ****
      make all
      Building file: ../src/Storage/FileStore.cpp
      Invoking: Cross G++ Compiler
      arm-none-eabi-g++ -D__SAM4E8E__ -DCORE_NG -DDUET_NG -DDUET_ETHERNET -Dprintf=iprintf
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\cores\arduino"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\libraries\Flash"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\libraries\SharedSpi"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\libraries\Storage"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\libraries\Wire"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\asf"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\asf\common\utils"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\asf\common\services\clock"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\asf\common\services\ioport"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\asf\sam\drivers\dmac"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\asf\sam\drivers\efc"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\asf\sam\drivers\matrix"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\asf\sam\drivers\pdc"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\asf\sam\drivers\pmc"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\asf\sam\drivers\spi"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\asf\sam\drivers\twi"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\asf\sam\services\flash_efc"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\asf\sam\utils"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\asf\sam\utils\cmsis\sam4e\include"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\asf\sam\utils\header_files"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\asf\sam\utils\preprocessor"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\asf\thirdparty\CMSIS\Include"
      -I"C:\workdir\fHDX\Duet Refactor\CoreNG\variants\duetNG"
      -I"C:\Users\joaos\git\RepRapFirmware\src"
      -I"C:\Users\joaos\git\RepRapFirmware\src\DuetNG"
      -I"C:\Users\joaos\git\RepRapFirmware\src\DuetNG\DuetEthernet"
      -I"C:\Users\joaos\git\RepRapFirmware\src\DuetNG\DuetEthernet\Wiznet\Ethernet" -O2 -Wall -c -std=gnu++11 -mcpu=cortex-m4 -mthumb -mfpu=fpv4-sp-d16 -mfloat-abi=softfp -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fno-exceptions -nostdlib "-Wa,-ahl=FileStore.s" -MMD -MP -MF"src/Storage/FileStore.d" -MT"src/Storage/FileStore.o" -o "src/Storage/FileStore.o" "../src/Storage/FileStore.cpp"
      In file included from C:\workdir\fHDX\Duet Refactor\CoreNG\asf/asf.h:36:0,
                       from C:\workdir\fHDX\Duet Refactor\CoreNG\cores\arduino/Core.h:44,
                       from C:\Users\joaos\git\RepRapFirmware\src/RepRapFirmware.h:30,
                       from ../src/Storage/FileStore.cpp:3:
      C:\workdir\fHDX\Duet Refactor\CoreNG\asf/sam/services/flash_efc/flash_efc.h:51:21: fatal error: efc/efc.h: No such file or directory
       #include "efc/efc.h"
      compilation terminated.
      make: *** [src/Storage/FileStore.o] Error 1
      I have searched the forum for similar issues and found these:
      https://www.duet3d.com/forum/thread.php?id=2720#p25326
      https://www.duet3d.com/forum/thread.php?id=3378#p29756
      …however I still couldn't find the solution.
      Could anyone give me any pointers as to where eclipse could be going wrong? Really appreciate the help.
      J
        It looks to me that your .cproject file isn't up to date with the source code. In a recent commit, most of the folders of the form "CoreNG\asf\sam\drivers\xxx" were removed from the RepRapFirmware project include path, and "CoreNG\asf\sam\drivers" was added.
        • jpsantosundefined
          jpsantos
          Hmm, you are correct, my .cproject does still have all the individual "CoreNG\asf\sam\drivers\xxx".
          I checked the current version on the master branch and it's identical, though.
          As an experiment, I dropped the dev version of .cproject and the error I initially pointed out disappeared but soon it started hitting weird errors so I stopped.
          It doesn't seem possible to edit the Cross G++ Compiler > All Options field. How do I change them btw?
          Also should I simply use dev instead of master? I assumed dev was less stable.
          I'm going to try dev branch tonight and see how far I get.
            Yes you should use the dev branch of RepRapFirmware (it's the default branch), and the master branch of CoreNG.
            • jpsantosundefined
              jpsantos
              Had a go last night and managed to push it forward but still bombing out as so:
              [c]Building target: DuetEthernetFirmware.elf
              Invoking: Cross G++ Linker
              arm-none-eabi-gcc -L"C:\workdir\fHDX\Duet Refactor\CoreNG\SAM4E8E" -Os -Wl,–gc-sections -Wl,--fatal-warnings -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -TC:\workdir\fHDX\Duet Refactor\CoreNG\variants\duetNG\linker_scripts\gcc\flash.ld -Wl,-Map,C:\workdir\fHDX\Duet Refactor\RepRapFirmware\DuetEthernet/DuetEthernetFirmware.map -o "DuetEthernetFirmware.elf" -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group "C:\workdir\fHDX\Duet Refactor\CoreNG\SAM4E8E\cores\arduino" ./src/Tools/Filament.o ./src/Tools/Tool.o ./src/Storage/CRC32.o ./src/Storage/FileStore.o ./src/Storage/MassStorage.o ./src/Movement/Kinematics/CartesianKinematics.o ./src/Movement/Kinematics/CoreBaseKinematics.o ./src/Movement/Kinematics/CoreXYKinematics.o ./src/Movement/Kinematics/CoreXYUKinematics.o ./src/Movement/Kinematics/CoreXZKinematics.o ./src/Movement/Kinematics/Kinematics.o ./src/Movement/Kinematics/LinearDeltaKinematics.o ./src/Movement/Kinematics/PolarKinematics.o ./src/Movement/Kinematics/ScaraKinematics.o ./src/Movement/Kinematics/ZLeadscrewKinematics.o ./src/Movement/BedProbing/Grid.o ./src/Movement/BedProbing/RandomProbePointSet.o ./src/Movement/DDA.o ./src/Movement/DriveMovement.o ./src/Movement/Move.o ./src/Libraries/sha1/sha1.o ./src/Libraries/Math/Isqrt.o ./src/Libraries/General/IP4String.o ./src/Libraries/General/StringRef.o ./src/Libraries/Fatfs/ccsbcs.o ./src/Libraries/Fatfs/diskio.o ./src/Libraries/Fatfs/fattime_rtc.o ./src/Libraries/Fatfs/ff.o ./src/Heating/Sensors/CpuTemperatureSensor.o ./src/Heating/Sensors/CurrentLoopTemperatureSensor.o ./src/Heating/Sensors/DhtSensor.o ./src/Heating/Sensors/RtdSensor31865.o ./src/Heating/Sensors/SpiTemperatureSensor.o ./src/Heating/Sensors/TemperatureSensor.o ./src/Heating/Sensors/Thermistor.o ./src/Heating/Sensors/ThermocoupleSensor31855.o ./src/Heating/Sensors/ThermocoupleSensor31856.o ./src/Heating/Sensors/TmcDriverTemperatureSensor.o ./src/Heating/FOPDT.o ./src/Heating/Heat.o ./src/Heating/Pid.o ./src/Heating/TemperatureError.o ./src/GCodes/GCodeBuffer.o ./src/GCodes/GCodeInput.o ./src/GCodes/GCodeMachineState.o ./src/GCodes/GCodeQueue.o ./src/GCodes/GCodes.o ./src/GCodes/GCodes2.o ./src/GCodes/RestorePoint.o ./src/FilamentSensors/Duet3DFilamentSensor.o ./src/FilamentSensors/FilamentSensor.o ./src/FilamentSensors/SimpleFilamentSensor.o ./src/DuetNG/DuetEthernet/Wiznet/Internet/DHCP/dhcp.o ./src/DuetNG/DuetEthernet/Wiznet/Ethernet/W5500/w5500.o ./src/DuetNG/DuetEthernet/Wiznet/Ethernet/WizSpi.o ./src/DuetNG/DuetEthernet/Wiznet/Ethernet/socketlib.o ./src/DuetNG/DuetEthernet/Wiznet/Ethernet/wizchip_conf.o ./src/DuetNG/DuetEthernet/Network.o ./src/DuetNG/DuetEthernet/Socket.o ./src/DuetNG/DueXn.o ./src/DuetNG/FirmwareUpdater.o ./src/DuetNG/FtpResponder.o ./src/DuetNG/HttpResponder.o ./src/DuetNG/NetworkBuffer.o ./src/DuetNG/NetworkResponder.o ./src/DuetNG/SX1509.o ./src/DuetNG/TMC2660.o ./src/DuetNG/TelnetResponder.o ./src/Fan.o ./src/IoPort.o ./src/Logger.o ./src/OutputMemory.o ./src/Platform.o ./src/PortControl.o ./src/PrintMonitor.o ./src/RepRap.o ./src/RepRapFirmware.o ./src/Roland.o ./src/Scanner.o ./src/SoftTimer.o ./src/ZProbeProgrammer.o -lCoreNG -Wl,--end-group -lm -gcc
              arm-none-eabi-gcc.exe: error: RefactorCoreNGvariantsduetNGlinker_scriptsgccflash.ld: No such file or directory
              arm-none-eabi-gcc.exe: error: RefactorRepRapFirmwareDuetEthernet/DuetEthernetFirmware.map: No such file or directory
              make: *** [DuetEthernetFirmware.elf] Error 1[/c]
              It seems it's getting confused with the '' in the cmd string and ignoring them. Might be a weird Eclipse windows issue. I'll try to manually fix this and report back.
              • jpsantosundefined
                jpsantos
                Ok it works now.
                I swapped the problematic eclipse macros from my build/link cmds with hardcoded paths and this moved the compilation fwd.
                **[Note]**On windows, Eclipse uses '/' when it expands env paths instead of the '' which is used throughout the project config; eclipse misunderstands the paths when '/', '' are mixed in the same path and this was the root of all my compilation errors.
                I got to the last stage 'post-build' and it failed because the elf file it was expecting did not existed. Upon inspection, I noted the output file existed but without the .elf extension so I changed my post-build cmd to:
                [c]arm-none-eabi-objcopy -O binary C:/workdir/fHDX/Duet_Refactor/RepRapFirmware/DuetEthernet/DuetEthernetFirmware C:/workdir/fHDX/Duet_Refactor/RepRapFirmware/DuetEthernet/DuetEthernetFirmware.bin[/c]
                Is it worth creating some kind of separate eclipse quick-start helper instructions and post it together with the build instructions?
                  From your earlier error message listing it looks like you were using a path with a space in it: "C:\workdir\fHDX\Duet Refactor". That won't work unless you use quotation marks around all the filenames that the path appears in.
                  Within Eclipse under Windows, I found that it generally doesn't matter whether you use / or \ as a path separator.
                  • jpsantosundefined
                    jpsantos
                    Yes! Good catch, I removed the space indeed but forgot to mention it in my earlier post.
                    Ok, perhaps it's something else then but the compiler/linker is parsing the paths wrongly as is.
                    I will reset the project in a separate folder and note down all the errors I get, when I have some time.
                    I really appreciate the prompt help so far!
                      Btw I just experienced the problem that some other users have reported, which is that the expression "${workspace_loc:/${CoreName}/SAM4E8E/cores/arduino/syscalls.o}" in the linker command line got expanded to "". Right-clicking on the project and selecting Refresh resolved it.
