    object model aktiv extruder on an Idex
    Gcode meta commands
    • Proschi3Dundefined
      Proschi3D
      can someone tell me what the code should look like if i want to use the if command on the active extruder?
      if {move.extruders[0].filament = "PLA"}
       if {sensors.gpIn[1].value = 0}
         M300 S600 P1000
         G4 S2
         M300 S600 P1000
         G4 S2
         M300 S600 P1000
         G4 S2
         M291 P"Tür oder Deckel geschlossen" R"Es wird PLA gedruckt bitte Deckel öffnen" S3
      Love my Duet 3 Mini.
      https://www.instagram.com/proschi3d
      https://youtube.com/@proschi3d
      https://www.proschi3d.de
      • chrishammundefined
        chrishamm administrators @Proschi3D
        @Proschi78 This should work:
        if state.currentTool >= 0 && #tools[state.currentTool].extruders > 0
          var toolExtruder = tools[state.currentTool].extruders[0]
          if move.extruders[{var.toolExtruder}].filament = "PLA" && sensors.gpIn[1].value = 0
           M300 S600 P1000
           G4 S2
           M300 S600 P1000
           G4 S2
           M300 S600 P1000
           G4 S2
        Duet software engineer
        Proschi3Dundefined 2 Replies Last reply Reply Quote 0
          Proschi3D @chrishamm
          @chrishamm unfortunately didn't work.
          But that's how it works
          Anyways thanks for your help
          if (move.extruders[0].filament == "PLA" || move.extruders[1].filament == "PLA")
             M300 S600 P1000
             G4 S2
             M300 S600 P1000
             G4 S2
             M300 S600 P1000
             G4 S2
            @chrishamm "The code you provided runs without errors, but there is neither a beep nor the M291 message displayed."
              @Proschi78 I don't know what the value of your second gpIn port is but that script works OK on my setup if a tool is selected and if I remove the gpIn check.
              Proschi3Dundefined 1 Reply Last reply Reply Quote 0
                @chrishamm said in object model aktiv extruder on an Idex:
                it's just a magnetic switch. 0 and 1
