    WCS Drop Down Menu
    CNC
    • Tinmanundefined
      Tinman
      The WCS dropdown menu in DWC acts a little funny. After a system start it doesn't show what WCS it currently uses (if it's not using a WCS it should probably say NA or something). When trying to select a WCS it seems to be offset by one value from the one that was selected. It doesn't stop me from running the machine however someone should probably look at it.
      Sindariusundefined 1 Reply Last reply Reply Quote 0
      • Sindariusundefined
        Sindarius @Tinman
        @Tinman wanted to let you know that a fix is in place for the WCS dropdown and will be in the next release.
        Tinmanundefined 1 Reply Last reply Reply Quote 2
        • Tinmanundefined
          Tinman @Sindarius
          @Sindarius That's excellent! Thanks!
