How to switch sbc to standalone Duet3 mini5+?
i did configure my Duet3 mini5+ wifi as sbc a long time ago, now i want toswitch to standalone mode, how do i do this ?
greetings
@Bulli Download all files from Files -> System to make a backup of your current system. Then take (ideally) a new microSD card, format it with FAT32, and create a "sys" folder. Then extract the backup ZIP into it. You'll also need to set up the www directory to get DWC back. Follow https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet for further info.
Hello, Thanks for your Help Chris,
My Problem is, with USB- Cable and YAT i can not start the WiFi, no chance. When i try to start Wifi, an Error comes and tells, no Network Things in SBC Mode, so without Raspi you have no Chance to switch to Standalone Mode. Is that right ?
Greetings
@Bulli if it's still trying to start in SBC mode, that means that there is no SD card in the Duet, or that there is no config.g file in /sys on the SD card.
today i did a new SD-Card as showed in the Duet Doku. It was susessful, i Formated, made the Folders and put it in the Duet. With USB connected i made Firmware Update and i can now connect to my Duet without the Raspi.
Many Thanks to Chrishamm and DC42
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
