    Q: How to check the type of a variable?
    Firmware wishlist
    • AndMazundefined
      AndMaz
      Is there a way to check the type of a variable? Something like typeof(global.fanSpeed) and result would be bool, int, float, string, DateTime, object or array
      If this is not possible atm, can you please add this feature? It will help a lot with params validation
      dc42undefined 1 Reply Last reply Reply Quote 1
        dc42 administrators @AndMaz
        @AndMaz I'm sorry, we don't currently provide a way to check the type of a variable, other than to check if it is null. Can you provide more details about the use case?
        AndMazundefined 1 Reply Last reply Reply Quote 0
        • AndMazundefined
          AndMaz @dc42
          @dc42 I would like to validate the input before doing any actual printing. For example, in M98 P"my-macro.g" S100 Y"123" the Y value is passed as a string instead of a int.
            @AndMaz I creates this github issue https://github.com/Duet3D/RepRapFirmware/issues/865.
            dc42 created this issue in Duet3D/RepRapFirmware
            open [FeatureRequest]: Add a means to check the type of a variable #865
