unknown value 'heater^.current
I am using a E3D toolchanger with 4 individual printheads. FW 3.45
The first line of my macro to brush the nozzel for heater 1 is not working.
I want to make sure, that the printheads temperture is high enough.
I get the attached error message.if {heat.heater[1].current > heat.heaters[1].active - 5} && {heat.heater[1].current > 150};min temperature to work
M400
;brush in
G1 X331.3 Y150 F50000
G1 X331.3 Y100 F50000
G1 X331.3 Y170 F50000
M400
else
echo "tenmp to low to brush"T0
Error: in file macro line 1 column 5: meta command: unknown value 'heater^.current'What is my mistake?
Thanks! -
@Mike-1 said in unknown value 'heater^.current:
You used "heaters" in some places (correct) but "heater" in other places (not correct).
@dc42 Thanks! Issue can be closed
undefined droftarts marked this topic as a question
undefined droftarts has marked this topic as solved
