    [Possible bug] Params parsing
    Firmware wishlist
    • AndMazundefined
      AndMaz
      Hi
      I'm facing a weird problem in params parsing with v3.4.5 and v3.5.0-beta4. For some reason param.E is being ignored in some scenarios.
      Here's a repro code.
      Contents of the test.g
      echo "param.I="^param.I
      echo "param.R="^param.R
      echo "param.S="^param.S
      echo "param.L="^param.L
      echo "param.O="^param.O
      echo "param.B="^param.B
      echo "param.C="^param.C
      echo "param.D="^param.D
      echo "param.E="^param.E
      echo "param.F="^param.F
      echo "param.H="^param.H
      NOT OK - param.E not parsed
      M98 P"0:/macros/test.g" I"test" Rtrue S1800 Ltrue O0 B0.7 C0.7 D0.7 F0.7 H0.7 E0.6
      Result:
      param.I=test
      param.R=true
      param.S=1800
      param.L=true
      param.O=0
      param.B=0.7
      param.C=0.7
      param.D=0.7
      param.E=null <--- param.E was not parsed and the value is null
      param.F=0.7
      param.H=0.7
      OK - - param.E parsed as it should
      Command:
      M98 P"0:/macros/test.g" E0.6 I"test" Rtrue S1800 Ltrue O0 B0.7 C0.7 D0.7 F0.7 H0.7
      Note: param.E comes in the first place
      Result:
      param.I=test
      param.R=true
      param.S=1800
      param.L=true
      param.O=0
      param.B=0.7
      param.C=0.7
      param.D=0.7
      param.E=0.6 <-- parsed as it should
      param.F=0.7
      param.H=0.7
      Is E a reserved key? Do we need to pass params in alphabetical order to be properly parsed?
      dc42undefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @AndMaz
        @AndMaz thanks for reporting this. I confirm it is a bug. I will schedule it for fixing in the next 3.5 beta or release candidate.
        https://github.com/Duet3D/RepRapFirmware/issues/878
        dc42 created this issue in Duet3D/RepRapFirmware
        closed Can't pass E parameter to M98 unless it is the first parameter #878
          @AndMaz I found the problem. In your command:
          the parameters Rtrue and Ltrue are not valid. Ideally, RRF would issue an error message for each of them. The letters in "true" are causing null T, R, U and E parameters to be created.
          You can pass "true" using { } like this:
          M98 P"0:/macros/Parameter test" I"test" R{true} S1800 L{true} O0 B0.7 C0.7 D0.7 F0.7 H"test" E0.6 H0.7
          AndMazundefined 1 Reply Last reply Reply Quote 2
          • AndMazundefined
            AndMaz @dc42
            @dc42 thank you very much for quick response. You're a lifesaver!
            • droftartsundefined droftarts marked this topic as a question
            • droftartsundefined droftarts has marked this topic as solved
            • dc42undefined dc42 has marked this topic as unsolved
            • shugo1110undefined
              shugo1110
              i see that my "invalid value for parameter '-'"-errors are related to this bug report.
              With the current allowed-chars-list i get an error when i do a
              M98 P"0:/anymacro" S-1
              until this fix i also could do a
              M98 P"0:/sys/home.g" XYZ
              this is resulting in an error now.
                dc42 administrators @shugo1110
                @shugo1110 said in [Possible bug] Params parsing:
                That's a bug - thanks for reporting it. Workaround: use S{-1}.
                That's intentional. In most contexts, parameter letters must be followed by a value for that parameter. Older versions of RRF assumed a zero value if none was given, but that sometimes made it harder to diagnose what was wrong in the command line.
