FTP does not properly respond to "LIST -a"
Beta Firmware
  • undefined
    adambx
    I am using wget to download files from the SD Card using FTP. worked so far for 3.4, but has stopped working in 3.5.
    After some research it turns out that the newly introduced feature of supporting LIST <dir> does not take into account the -a flag that is sent by many FTP clients including wget.
    there is a discussion here:
    https://savannah.gnu.org/bugs/?59954
    The relevant change is here. Should an error be returned on LIST -a?
    https://github.com/Duet3D/RepRapFirmware/commit/7e11027b22a0720d756369393bf96d94a2c01b9a#diff-1608ecf6e91dd6a71fa80c16d6c79cc2e79f5b6ed17ab92a97b8fd8de96d1dd4R675-R678
    i guess if an error is returned, wget will retry with "LIST", that's the usual behaviour.
    debug output of wget looks like this:
    230 Login successful.
    Logged in!
    ==> SYST ...
    --> SYST
    215 UNIX Type: L8
    done.
    UNIX TYPE L8: I know it and I will use "LIST -a" as standard list command
    Cheers
    Adam
    0 dc42 committed 16 Feb 2023, 09:16 to Duet3D/RepRapFirmware
    Support the directory parameter in the FTP LIST command
    undefined undefined undefined 4 Replies Last reply 11 Jul 2023, 16:42 Reply Quote 0
    • undefined
      droftarts administrators @adambx
      @adambx thanks for reporting this, I’ll mark it for the attention of @dc42.
      • undefined
        dc42 administrators @adambx
        @adambx if I provide you with a new RRF binary, can you test it? Which Duet are you using?
        PS - I created https://github.com/Duet3D/RepRapFirmware/issues/882.
        dc42 created this issue 18 Jul 2023, 09:47 in Duet3D/RepRapFirmware
        closed FTP server doesn't support LIST -a nor does it return an error #882
        • undefined
          @adambx we are closing this issue because you have not responded.
          • undefined
            chrishamm administrators @adambx
            @adambx @dc42 I can confirm the latest firmware version works with wget and LIST -a.
            Duet software engineer
            • undefined dc42 marked this topic as a question 5 Aug 2023, 07:14
            • undefined dc42 has marked this topic as solved 5 Aug 2023, 07:14
