    Macro for PrusaSlicer : Automatically Probe Only Print Area
    Gcode meta commands
    1
    1
    255
    • KP0005undefined
      KP0005
      I made a macro that alters your bed grid to the area the printer is actually printing on.
      Inspired by https://forum.duet3d.com/topic/15302/cura-script-to-automatically-probe-only-printed-area
      Features:
      • makes sure the requested grid fits your probeable area (not neccesarily the same as the printable area)
      • makes sure the grid is at least 3x3 points
      • the grid is centered on the print and expanded to fit a whole number of constant size squares
      • has two defined probe spacings - fine for small prints, coarse for large prints, so that you don't take ages to probe the entire bed
      Works with prusaslicer and perhaps others
      How to use:
      • put the script into your /sys folder
      • open it and edit the constants for your machine (read the comments)
      • in PrusaSlicer, go to Printer settings / Custom G-code and replace G29 in your Start G-code with
      M98 P"localised_mesh_bed.g" A[first_layer_print_min_0] B[first_layer_print_max_0] C[first_layer_print_min_1] D[first_layer_print_max_1] ; only probe the part of the bed that you're printing on
      • add a command to reset the grid back to normal to your End G-code
      M557 X24:228 Y6:210 S51 ; reset bed grid
      • Those numbers are for my machine, please replace with your own.
      1 Reply Last reply Reply Quote 6
      • Phaedruxundefined Phaedrux moved this topic from Tuning and tweaking
