    Why ?
    Firmware wishlist
    675
    • A Former User?
      A Former User
      This post is deleted!
      chrishammundefined Hugsyundefined 2 Replies Last reply Reply Quote 1
      • chrishammundefined
        chrishamm administrators @A Former User
        @Herve_Smith Fair enough, I can omit the countdown a second time if a heater was reset before in the same brower session.
        If you get too many heater faults because the temperature fluctuates too much, consider tuning the heater again and if that doesn't help, maybe adjust the heater fault detection via M570.
        Duet software engineer
        • Hugsyundefined
          Hugsy @A Former User
          @Herve_Smith If you compile your own DWC, changing the countdown from a few seconds to zero is actually quite easy. It's the" countdownSeconds" variable in src/components/dialogs/ResetHeaterFaultDialog.vue
          • A Former User?
            A Former User @chrishamm
              dc42 administrators @A Former User
              @Herve_Smith said in Why ?:
              for me everything rapidly heats to within 5c of my target temp then seems to grind to a halt and takes what feels like forever to get from the temp it stops at to then reach my target temp
              It sounds to me that the tuning isn't quite right. Can you post a sample graph of the temperature while heating up?
              • A Former User?
                A Former User @dc42
                • A Former User?
                  A Former User
                  Herniczundefined 1 Reply Last reply Reply Quote 0
                  • Herniczundefined
                    Hernicz @A Former User
                    @Herve_Smith Maybe setting K to K0:0 would solve your issue. It's fan compensation.
                    You can test it first (before changing K) by heating up to target temp and then turn on the fan to 100%
                    If your temp starts to climb while M307 K is non-zero then thats your issue.
                    There are known knowns and known unknowns, things we know that we don't know. But there are also unknown unknowns.
                    • A Former User?
                      A Former User @Hernicz
                      • deckingmanundefined
                        deckingman @A Former User
                        @Herve_Smith I don't have an answer to your problem - not experiencing it myself but here is a hack that might work. Personally, I don't use M codes to wait for heaters for a number of reasons which have no bearing on your problem but instead use this format
                        while sensors.analog[1].lastReading < someNumber
                           G4 S5
                        So maybe you could cobble together a hack whereby you set your temperature to be say 5 deg above what you really want, then use that while loop to wait for the actual desired temperature (i,e 5 degrees less tha what you've just asked for) and when it reaches it, set the temperature to your desired temperature and continue. e.g.
                        M568 P0 R205 S205
                        while sensors.analog[1].lastReading <200
                          G4 S5
                        M568 P0 R200 S200.
                        Or something along those lines
                        • A Former User?
                          A Former User @deckingman
