Duex5 Pin callout names
I have an expansion board Duex5 that I am using with my Duet2 WIFI board and I am not sure if I am calling the pins correctly. On the expansion board I am using pins E2-Stop, E3-stop and E4-stop as general inputs. I am trying to set it up so that if the condition is not met then the program will not run a path. Once the conditions are met the machine can run a path. If at any point a condition changes state during a path I would like the machine to pause or even just have a screen popup. I know to call the message M581 is used. I noticed on your diagram with the pins there are a few different names to call them out. What are the names I should be using? I have used all of the names that I can see but it doesn't seem to be calling them correctly. Is there a way that I can see what I being triggered with the pin names?
Firmware: 3.4.6
Config:
42aa476b-00e0-4dc2-acc8-f7e0ff02e980-config.g -
As I replied to your other thread, the pin names can be found here: https://docs.duet3d.com/en/Duet3D_hardware/Duet_2_family/DueX2_and_DueX5#pin-names
