    Daemon.g logging incorrect file position.
    Gcode meta commands
    daemon.g object model
    289
    • tdowns7undefined
      tdowns7
      I'm trying to log the file position from the daemon to see how temperature and humidity in the print chamber change throughout the print. However, I've noticed that when I log the object model property "job.filePosition" from the daemon it doesn't appear to be the correct file position.
      Here's a gcode file that I've been using to test this.
      M929 P"0:/gcodes/Logs/Print Logs/DaemonLogTest.csv" S3
      M118 P1 S{"Line 3, File Position," ^ job.filePosition} L3
      G4 S5
      M118 P1 S{"Line 5, File Position," ^ job.filePosition} L3
      M118 P1 S{"Line 7, File Position," ^ job.filePosition} L3
      G4 S5
      M118 P1 S{"Line 9, File Position," ^ job.filePosition} L3
      M118 P1 S{"Line 11, File Position," ^ job.filePosition} L3
      G4 S5
      M118 P1 S{"Line 13, File Position," ^ job.filePosition} L3
      M118 P1 S{"Line 15, File Position," ^ job.filePosition} L3
      G4 S5
      M118 P1 S{"Line 17, File Position," ^ job.filePosition} L3
      M929 S0
      My daemon.g file(global.daemonLoopTime=10):
      while true
      	; Log sensor data if a file is being printed and the enable variable is set to true.
      	if job.file.fileName != null && global.daemonLogEnable == true
      		M118 L2 S{",Chamber Temp, " ^ sensors.analog[global.chmbr_temp].lastReading ^ ",File Position," ^ job.filePosition ^ " "}
      		M118 L2 S{",Chamber Humidity, " ^ sensors.analog[global.chmbr_humid].lastReading ^ ",File Position," ^ job.filePosition ^ " "}
      	else
      		; don't log
      	G4 S{global.daemonLoopTime} ; Pause every X seconds
      And the resulting log file.
      2023-08-28 10:10:47 [info] Event logging started at level debug
      2023-08-28 10:10:47 [info] Running: Duet 3 MB6HC v1.01: 3.4.5 (2022-11-30 19:35:23)
      2023-08-28 10:10:47 [debug] Line 3, File Position,56
      2023-08-28 10:10:52 [debug] Line 5, File Position,120
      2023-08-28 10:10:52 [debug] Line 7, File Position,179
      2023-08-28 10:10:55 [info] ,Chamber Temp, 2000.00,File Position,36
      2023-08-28 10:10:55 [info] ,Chamber Humidity, 2000.00,File Position,165
      2023-08-28 10:10:57 [debug] Line 9, File Position,243
      2023-08-28 10:10:57 [debug] Line 11, File Position,302
      2023-08-28 10:11:02 [debug] Line 13, File Position,367
      2023-08-28 10:11:02 [debug] Line 15, File Position,427
      2023-08-28 10:11:05 [info] ,Chamber Temp, 2000.00,File Position,285
      2023-08-28 10:11:05 [info] ,Chamber Humidity, 2000.00,File Position,414
      2023-08-28 10:11:07 [debug] Line 17, File Position,492
      2023-08-28 10:11:07 [info] Event logging stopped
      Firmware: RepRapFirmware for Duet 3 MB6HC 3.4.5 (2022-11-30)
      • chrishammundefined
        chrishamm administrators @tdowns7
        @tdowns7 Why do you think it is wrong? The current file position may be way ahead of the current move being done because RRF needs to calculate the moves in advance.
        Duet software engineer
        tdowns7undefined 1 Reply Last reply Reply Quote 0
        • tdowns7undefined
          tdowns7 @chrishamm
          @chrishamm Going off the timestamps, it looks like the daemon log commands are executed between Line 7 and 9 of the job file. But the byte positions logged by the daemon are before Line 7.
          I'm assuming that the daemon runs during the dwell command in this case. So I'd expect that the byte positions logged by the daemon would be between 179 and 243.
          M118 P1 S{"Line 7, File Position," ^ job.filePosition} L3; File Position = 179
          G4 S5
          M118 P1 S{"Line 9, File Position," ^ job.filePosition} L3; File Position = 243
            @tdowns7 Thanks, can you confirm the problem persists with RRF 3.4.6?
            • tdowns7undefined
              tdowns7 @chrishamm
              @chrishamm Yes, this did persist when I updated to RRF3.4.6
              2023-08-28 16:11:10 [info] Event logging started at level debug
              2023-08-28 16:11:10 [info] Running: Duet 3 MB6HC v1.01: 3.4.6 (2023-07-21 14:11:38)
              2023-08-28 16:11:10 [debug] Line 3, File Position,57
              2023-08-28 16:11:15 [debug] Line 5, File Position,121
              2023-08-28 16:11:15 [debug] Line 7, File Position,181
              2023-08-28 16:11:18 [info] ,Chamber Temp, 2000.00,File Position,38
              2023-08-28 16:11:18 [info] ,Chamber Humidity, 2000.00,File Position,167
              2023-08-28 16:11:20 [debug] Line 9, File Position,245
              2023-08-28 16:11:20 [debug] Line 11, File Position,305
              2023-08-28 16:11:25 [debug] Line 13, File Position,370
              2023-08-28 16:11:25 [debug] Line 15, File Position,431
              2023-08-28 16:11:28 [info] ,Chamber Temp, 2000.00,File Position,289
              2023-08-28 16:11:28 [info] ,Chamber Humidity, 2000.00,File Position,418
              2023-08-28 16:11:30 [debug] Line 17, File Position,496
              2023-08-28 16:11:30 [info] Event logging stopped
              chrishammundefined 2 Replies Last reply Reply Quote 0
                @tdowns7 I can reproduce this problem, we're looking into it.
                  @tdowns7 I could identify the cause of this bug and I've got a fix ready. It will be included in the upcoming v3.5-rc.1 and in v3.4.7, although I can't say yet when we will release the latter.
                  tdowns7undefined 1 Reply Last reply Reply Quote 1
                  • tdowns7undefined
                    tdowns7 @chrishamm
                    @chrishamm , Thanks for the quick follow up, appreciate it! Linking the github issue for those who may want to track.
