    [3.5.0-rc.1] duet web control loosing connection
    Beta Firmware
    • muleundefined
      mule
      I just installed 3.5.0-rc.1 and duet web control is loosing its connection every 3 to 5 seconds. I tried it with Firefox and Chrome and it happens on both. Downgrading to 3.4.6 did solve the issue.
      I remember that this also had happended after I tried 3.5.0-Beta4 some time ago but sadly had no time for further investigation.
      After updating only the main- and toolboard firmware and letting DWC 3.4.6 untouched showed no resets.
      The browser console of chrome shows the following messages while DWC is loosing its connection:
      PollConnector.ts:265     GET http://192.168.178.160/rr_model?flags=d99fn 503 (Service Unavailable)
      (anonymous) @ PollConnector.ts:265
      request @ PollConnector.ts:168
      updateLoop @ PollConnector.ts:521
      doUpdate @ PollConnector.ts:781
      setTimeout (async)
      scheduleUpdate @ PollConnector.ts:303
      updateLoop @ PollConnector.ts:644
      await in updateLoop (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      reconnect @ PollConnector.ts:390
      await in reconnect (async)
      reconnect @ index.ts:218
      wrappedActionHandler @ vuex.esm.js:851
      dispatch @ vuex.esm.js:516
      boundDispatch @ vuex.esm.js:406
      onConnectionError @ index.ts:248
      se.dispatch @ vuex.esm.js:779
      onConnectionError @ index.ts:1013
      onConnectionError @ BaseConnector.ts:184
      doUpdate @ PollConnector.ts:783
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      (anonymous) @ PollConnector.ts:217
      Promise.then (async)
      ce.onload @ PollConnector.ts:215
      load (async)
      (anonymous) @ PollConnector.ts:169
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      (anonymous) @ PollConnector.ts:225
      setTimeout (async)
      ce.onload @ PollConnector.ts:224
      load (async)
      load (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      index.ts:999 Error: Operation failed (Reason: Service Unavailable)
          at new ExtendableBuiltin (app.1a9e8c80.js:306:363023)
          at new NetworkError (errors.ts:24:3)
          at new OperationFailedError (errors.ts:50:3)
          at ce.onload (PollConnector.ts:231:14)
      onConnectionError @ index.ts:999
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      setTimeout (async)
      PollConnector.ts:265     GET http://192.168.178.160/rr_model?key=inputs&flags=d99vn 503 (Service Unavailable)```
      • chrishammundefined
        chrishamm administrators @mule
        @mule How many DWC sessions/tabs do you have open when this happens?
        Duet software engineer
        muleundefined 1 Reply Last reply Reply Quote 0
        • muleundefined
          mule @chrishamm
          @chrishamm Only one session has been open
            @mule What board do you have?
            • muleundefined
              mule @chrishamm
              @chrishamm It is an 6HC
              Maybe it has something to do with the following:
              I am using the duet hardware on a BLV mgn printer with an arduino which polls (M409 K"job" and M409 F"d99f") the duet via serial port in order to get the hotend temperature, bed temperature and printer status to show them via neopixels. The polling frequence is set to 3 seconds. Using this since ages now.
                @mule Well, HTTP code 503 means that the Duet has no more output memory. Does the situation improve when you turn off the Arduino?
