Config tool generates deprecated command
The (old) config tool generates the deprecated M568 "enable mixing" command when enabling mixxing extruders:
; Tools M563 P0 D0:1 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M568 P0 S1 ; enable mixing for tool 0 M567 P0 E0.5:0.5 ; set mixing ratios for tool 0
This results in setting the active temperature to 1C at startup.
This doesn't happen with the new config tool, but there's also no option to set the mixxing ratio
undefined Phaedrux marked this topic as a question
