    M567: Set tool mix ratios -- missing information
    Documentation
    • nikschaundefined
      nikscha
      Hi all,
      The wiki entry for M567: Set tool mix ratios is missing information on the P parameter.
      3b589d68-b7c0-4508-93b9-ac63d92dde59-image.png I think it should be mentioned that leaving the P parameter out will default to the active tool:
      Pnnn Tool number. If this parameter is not provided, the current tool is used.
      Stay in school
      droftartsundefined 1 Reply Last reply Reply Quote 2
        droftarts administrators @nikscha
        @nikscha Thanks, I've updated the Gcode dictionary. https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m567-set-tool-mix-ratios
        • droftartsundefined droftarts marked this topic as a question
        • droftartsundefined droftarts has marked this topic as solved
