    HTTP request timed out
    Duet Web Control
    312
    • StevenLundefined
      StevenL
      I'm getting HTTP time outs. Cant figure out why.
      errors:
      10/14/2023, 1:36:53 AM Failed to upload Boom Guide plate_0.3mmPLA.gcode
      Could not complete action because the connection has been terminated
      10/14/2023, 1:36:52 AM Connection interrupted, attempting to reconnect...
      I'm running 3.4.6. Same issue when I was on 3.4.3
      I have troubleshot several ways. A small gcode file will upload fine (850kb). a 16,000kb file will timeout. buffer size somewhere? @dc42
        After an upload has failed can you send M122 and share the results?
        It may be worth trying a fresh SD card as well.
        to confirm that it's not an SD card issue, please copy one of those GCode files to a new filename ending in ".dummy" and try to upload it on the Jobs page of DWC. When RRF sees the ".dummy" file extension, it omits writing the file to SD card.
        • StevenLundefined
          StevenL
          m122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.6 (2023-07-21 14:08:28) running on Duet WiFi 1.02 or later + DueX5
          Board ID: 08DGM-9T6BU-FG3SN-6JKD6-3SN6L-KUW7G
          Used output buffers: 1 of 26 (26 max)
          Static ram: 23896
          Dynamic ram: 76268 of which 0 recycled
          Never used RAM 8076, free system stack 92 words
          Tasks: NETWORK(ready,1777.7%,211) HEAT(notifyWait,5.6%,308) Move(notifyWait,286.8%,294) DUEX(notifyWait,0.0%,24) MAIN(running,1809.8%,436) IDLE(ready,11.9%,30), total 3891.8%
          Owned mutexes: WiFi(NETWORK)
          Last reset 08:58:30 ago, cause: power up
          Last software reset at 2023-10-15 11:45, reason: User, GCodes spinning, available RAM 11920, slot 2
          Error status: 0x14
          Aux0 errors 0,0,0
          Step timer max interval 0
          MCU temperature: min 34.2, current 42.4, max 45.2
          Supply voltage: min 24.2, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
          Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/144/144, gc cycles 0
          Events: 0 queued, 0 completed
          Driver 0: standstill, SG min 0
          Driver 1: standstill, SG min 0
          Driver 2: standstill, SG min n/a
          Driver 3: standstill, SG min 0
          Driver 4: standstill, SG min n/a
          Driver 5: standstill, SG min 0
          Driver 6: standstill, SG min 0
          Driver 7: standstill, SG min 0
          Driver 8: standstill, SG min n/a
          Driver 9: standstill, SG min n/a
          Driver 10:
          Driver 11:
          Date/time: 2023-10-15 21:42:23
          Slowest loop: 255.21ms; fastest: 0.15ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 9.2ms, write time 500.9ms, max retries 0
          DMs created 83, segments created 41, maxWait 156036ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 593082, completed 593082, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
          === AuxDDARing ===
          Heater 0 is on, I-accum = 0.0
          Heater 1 is on, I-accum = 0.8
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty
          === DueX ===
          Read count 1, 0.00 reads/min
          === Network ===
          Slowest loop: 503.02ms; fastest: 0.00ms
          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
          HTTP sessions: 1 of 8
          = WiFi =
          Interface state: active
          WiFi firmware version 1.25
          WiFi MAC address 84:f3:eb:83:47:2a
          WiFi Vcc 3.30, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 26016
          WiFi IP address 192.168.200.184
          WiFi signal strength -37dBm, mode 802.11n, reconnections 0, sleep mode modem
          Clock register 00002002
          • StevenLundefined
            StevenL
            I've tried a fresh SD card.
            I've tried a different browser.
            It's only when UPLOADing a file via DWC. I can manually copy a file to the gcodes file and then i cant print. but thats a pain.
            I just tried the "rename to .dummy" and try the upload again. failed. Ajax timeout? Smaller uploads work.
              @StevenL said in HTTP request timed out:
              Your wifi firmware hasn't been updated along with your main firmware.
              Please try uploading this complete zip file and send M122 again so we can see if the wifi firmware has updated. Then see if you have the same problem updating .dummy files.
              https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.6/Duet2and3Firmware-3.4.6.zip
              • StevenLundefined
                StevenL
                10/19/2023, 10:14:52 PM m122
                Static ram: 23896
                Dynamic ram: 76060 of which 0 recycled
                Never used RAM 12124, free system stack 184 words
                Tasks: NETWORK(notifyWait,15.5%,237) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) DUEX(notifyWait,0.0%,24) MAIN(running,83.2%,436) IDLE(ready,1.3%,30), total 100.0%
                Last reset 00:01:08 ago, cause: software
                Error status: 0x04
                Aux0 errors 0,0,0
                MCU temperature: min 39.6, current 40.3, max 40.5
                Supply voltage: min 24.3, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                Driver 0: standstill, SG min n/a
                Driver 1: standstill, SG min n/a
                Driver 3: standstill, SG min n/a
                Driver 5: standstill, SG min n/a
                Driver 6: standstill, SG min n/a
                Driver 7: standstill, SG min n/a
                Driver 10:
                Driver 11:
                Date/time: 2023-10-19 22:14:52
                Cache data hit count 2451383707
                Slowest loop: 18.73ms; fastest: 0.18ms
                === Storage ===
                SD card longest read time 1.3ms, write time 0.0ms, max retries 0
                DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                === MainDDARing ===
                === AuxDDARing ===
                Heater 1 is on, I-accum = 0.0
                Segments left: 0
                Code queue is empty
                === DueX ===
                Read count 1, 0.87 reads/min
                === Network ===
                Slowest loop: 28.36ms; fastest: 0.00ms
                = WiFi =
                WiFi firmware version 1.27
                WiFi Vcc 3.30, reset reason Power up
                WiFi flash size 4194304, free heap 25368
                WiFi signal strength -35dBm, mode 802.11n, reconnections 0, sleep mode modem
                • StevenLundefined
                  StevenL
                  It look sto have updated to wifi 1.27.
                  I was successfully able to upload a large gcode file.
                  Question regarding the PanelDue on there... can it be upgraded? if so, how and what files?
                    Yes, the PanelDue can be updated. See here: https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue
