    Change to trigger input processing.
    Firmware wishlist
    1
    1
    103
    • fcwiltundefined
      fcwilt
      I just discovered that the using a GP input from a micro-switch, for a trigger input, doesn't work as expected or desired.
      The changes that would solve my current problem would be:
      • allow specifying de-bouncing of the input
      • allow specifying trigger execution on the closing of the switch, the opening of the switch or both - the both is really important.
      Without de-bouncing the current options of having the trigger execute on the rising edge or falling edge aren't very useful.
      The de-bounce option would make the "edge" options as intended. And then adding a rising or falling edge option would make a trigger handle more situations.
      Thanks much.
