Unclear interval in M42
The documentation for M42 says:
The S field may be in the range 0..1 or 0..255.
Is that a half open range [0,1[ i.e. excluding 1? If not, how does it distinguish if "1" is a low value in the 0..255 range or a high value in the 0..1 range?
For G1 the S parameter range is defined as:
S parameter sets laser power with range of 0 to 254.
So it would seem natural that M42 would have the same range (0..254), or then that G1 would also have 0.. 255. (255 would seem more logical to me, as it is the max byte value).
It is confusing.
To have values between 0 and 1 they must be fractional.
And I have always assumed they represent whole percentage values from 0 to 100.
Thus I have always used 0.00 to 1.00
I may be totally wrong.
P.S. Actually I use 0 to 255 - clear and unambiguous.
@Otso You are probably not going to like the answer! From the source code: https://github.com/Duet3D/RepRapFirmware/blob/3.5-remote-input-shaping/src/GCodes/GCodeBuffer/GCodeBuffer.cpp#L809
Remember that these things have almost certainly been this way for some time ande/or in effect defined by how things like slicers and other firmware use them. So may not be easy to change without causing issues for existing gcode etc.
@fcwilt said in Unclear interval in M42:
Thanks for clarifying. I think this should be said in the manual, as it is not fully clear right now, although one maybe could assume this is the way it is. It could say something like
“ The S field may be in the range 0..1 or 0..255. The values in the range 0..1 must be written as a fractional numbers, for example ‘1.0’.”
(0 will be 0 in any case, so it doesn’t matter which range it uses.)
P.S. Actually I 0 to 255 - clear and unambiguous.
Agree, as long as you read it in isolation. It’s when you look at G1 that you start wondering if either is a typo. Why would the range be 0 to 255 in one place and 0 to 254 in another, when both are basically setting the PWM value. To me it feels like G1 is a typo (i.e., that the range is actually 0..255), although it might be correct. I think the documentation for G1 could add some reassuring text explaining why it doesn’t go up to 255.
@gloomyandy Thank you for pointing out the code location. (Did you accidentally paste the same location twice?).
So giving “S1” (without a fraction) will actually convert to “1.0” (full PWM) and not 1/255, right?
float v = GetFValue(); if (v > 1.0) { v = v/255.0; } return constrain<float>(v, 0.0, 1.0); } I actually thought I might as well have a look at the code, but I thought this requires documentation clarification I wanted to discuss it here. So apparently the fractional range 0..1 is the new preferred way. I didn’t yet dig out the code for G1, but I’d assume it uses the same GetPwmFrequency() function, and thus accept the range 0..255 and not 0..254 as the documentation says. Maybe I should have a look at the code.
It would be nice if G1 also accepted the fractional range.
Anyway, if M42 really uses the above function then I’d consider it a bug. I’ll try “S1” it in practice right away.
Yes, this can be a pretty dangerous bug. I’m using firmware 3.4 and haven’t checked if it has been fixed.
I just tested with my laser and M42 S1 (no fraction) sets it at full power and not at 1/255 as one would expect from the documentation.
Either the code or the documentation needs to be fixed.
Personally I think this should be fixed in the code, especially if it is for backwards compatibility, where one can assume that “S1” previously set it at 1/255 of the power and since the introduction of fractions that changed it to full power.
With the firmware 3.4 implementation the documentation should say:
The S field may be in the range 0..1 or 2..255.
It should be noted that apparently values like 5.76 will probably also work, and be converted to 5.76/255. So the documentation could clarify that fractions are accepted, and the correct documentation would actually be:
The S field may be in the range [0,1] or ]1,255].
With further noting that the notation for the 1..255 range means any fractional value above, but not including, 1.
As a programmer with 30+ years of experience I am never surprised to see code like that.
Yes, in practice it works. After all how many times are folks going to specify a PWM value of 1 out of the range 0 to 255.
But it does mean the documentation is wrong and unclear. If 1 is converted to 1.0 then the range is not 0 to 255 but 2 to 255.
If the other range is 0.0 to 1.0 then accepting a value of 1 as meaning 1.0 is just... something. Maybe they were short of code space and had to conserve.
But as a disclaimer I am somewhat OCD and my code reflects that - I do not like ambiguity.
The code could start with a test of the incoming value to determine if it was a float or fixed. Often programming languages have procedures like isFloat or isTime and many others to be used to test a value. Moving on, then you would either force the float value to be in the range 0.0 to 1.0 or force the fixed value to be in the range 0 to 255. Unless you wish to flag out of range values as errors which could help detect typos/bugs by the end user.
Like most things in life there are compromises to be faced.
Question: where are you seeing this 0 to 254?
Thanks.
https://docs.duet3d.com/User_manual/Reference/Gcodes G1 documentation says:
RRF 3, G0/G1 S parameter AFTER M452 Laser Mode.
S parameter sets laser power with range of 0 to 254. -
@Otso I've fixed the link to the code used for G1 S it is here: https://github.com/Duet3D/RepRapFirmware/blob/47435151e110f373fc80721a2c265e38b8ec5e3b/src/GCodes/GCodes.cpp#L4770
@gloomyandy Oh and in case you are wondering laserMaxPower is set of M452 and defaults to 255.0
@gloomyandy said in Unclear interval in M42:
Thanks! I think I need to get to my computer to investigate the code more to figure where laserMaxPower is set, and what value it has in my case.
Pwm_t GCodes::ConvertLaserPwm(float reqVal) const noexcept { return (uint16_t)constrain<long>(lrintf((reqVal * 65535)/laserMaxPower), 0, 65535); } Edit: Thanks for giving the info about laserMaxPower.
This post is deleted! -
For example, if I use an application that converts a gray scale image to laser power, then some light pixels could map to 1 and cause the laser to blast out full power.
Or if you manually enable the laser at a very low level to set the laser focus or to line up the zero point. (I've been using S0.0001, but I could just as well have started with 1 and expecting it to be low power). Of course, you would notice the problem immediately and shut it down, but still, I don't like this I think it should be fixed.
@Otso If you are converting from grey scale you should really be using G1 S, which I don't think has any of these issues.
@Otso How do you propose fixing it without causing other problems with existing gcode/slicers/etc?
Looking at the code for M452:
if (gb.Seen('R')) { laserMaxPower = max<float>(1.0, gb.GetFValue()); } I haven't tested, but based on that it seems like R is expected to be in the range 0..1 and defaults 1.0, which makes the formula for ConvertLaserPwm() make sense. If that's correct, the manual on M452 is wrong or misleading:
Rnnn The value of the S parameter in G1 commands that corresponds to full laser power, default 255
@Otso I'm pretty sure the default is 255 (so the documentation is correct). If you specify a value with R it will be in the range 1 to whatever value you choose, that max function returns that largest value of 1 or your value, so in this case 1 is the minimum value you can set.
@gloomyandy Going back to the problem with M42, remember it is used to control things other than laser output (it sets a general pwm level). I suppose a possible fix might be to add a parameter to the M950 used to create the pin and allow that to specify what the range is that will be used by M42. At least that's the best I can come up with that would probably still allow most things to work as they do today.
Yes, you're totally correct, and so is the documentation. I wasn't thinking clearly.
I'd expect it to work like @fcwilt assumed it worked (and I did too), and that the code would check if it is "1" or "1.", and make the decision based on that. I think that wouldn't break anything, and would retain best backwards compatibility because that was how "1" was interpreted before fractions were introduced, and I'd assume those using fractions now will use 1.0 for full width pulse.
The quick and simple fix would be to mention this is the manual, just as a caution if nothing else.
