    Cant flash Duet Wifi after trying to flash Klipper unsuccessful
    Firmware installation
    • johnyundefined
      johny
      Hi there,
      I tried to test Klipper using a pi and the duet but gave up because I couldn't flash correctly with Klipper and tried several ways. Moving back to duet FW (it was working fine before) and i am not able to get a response from YAT. I flash with Bossa and verify with no problem but when i try to setup the wifi with YAT i have no response from the M commands. Any thoughts? Maybe the duet is semi-bricked? how can I reverse the situation?
      Thank you
        What procedure are you using to flash the Duet?
        https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#fallback-procedure-2
        This one should get you back up and running. If still not, see this guide.
        https://docs.duet3d.com/en/User_manual/Troubleshooting/Duet_wont_respond
