    [3.5 rc1+] Error while changing filament
    Beta Firmware
    • Diamondbackundefined
      Diamondback
      Hey,
      I'm getting a weird error while using the DWC "change filament" functionality:
      Error: M701: Unload the current filament before you attempt to load another one
      Error: Push(): stack overflow on HTTP
      I guess the first line is a follow-up to the stack overflow error?
      Any clue what might be happening here? I think this started with the 3.5rc1.
      M122:
      RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.1+ (2023-11-01 10:30:38) running on Duet 3 MB6HC v1.02 or later (standalone mode)
      Board ID: 08DJM-9P63L-DJ3T0-6J1F4-3S06S-9A1V9
      Used output buffers: 3 of 40 (33 max)
      Static ram: 154836
      Dynamic ram: 132700 of which 20 recycled
      Never used RAM 29620, free system stack 136 words
      Tasks: NETWORK(1,ready,36.2%,147) ETHERNET(5,nWait,0.3%,117) ACCEL(6,nWait,0.0%,348) HEAT(3,nWait,0.0%,325) Move(4,nWait,0.0%,216) CanReceiv(6,nWait,0.0%,795) CanSender(5,nWait,0.0%,334) CanClock(7,delaying,0.0%,350) TMC(4,nWait,8.3%,59) MAIN(1,running,55.1%,103) IDLE(0,ready,0.0%,30), total 100.0%
      Owned mutexes:
      Last reset 00:24:14 ago, cause: software
      Last software reset at 2023-11-12 12:49, reason: User, Gcodes spinning, available RAM 29468, slot 2
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      MCU temperature: min 40.9, current 42.1, max 42.2
      Supply voltage: min 23.5, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.2, current 12.3, max 12.5, under voltage events: 0
      Heap OK, handles allocated/used 495/405, heap memory allocated/used/recyclable 24576/24388/1184, gc cycles 337
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 0, mspos 456, reads 35702, writes 19 timeouts 0
      Driver 1: standstill, SG min 0, mspos 360, reads 35703, writes 19 timeouts 0
      Driver 2: standstill, SG min 0, mspos 424, reads 35703, writes 19 timeouts 0
      Driver 3: standstill, SG min 0, mspos 904, reads 35703, writes 19 timeouts 0
      Driver 4: standstill, SG min 0, mspos 520, reads 35699, writes 23 timeouts 0
      Driver 5: standstill, SG min 0, mspos 408, reads 35703, writes 19 timeouts 0
      Date/time: 2023-11-12 13:13:54
      Slowest loop: 13.69ms; fastest: 0.05ms
      === Storage ===
      Free file entries: 19
      SD card 0 detected, interface speed: 25.0MBytes/sec
      SD card longest read time 3.1ms, write time 2.3ms, max retries 0
      DMs created 125, segments created 6, maxWait 1308373ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
      no step interrupt scheduled
      Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
      === DDARing 0 ===
      Scheduled moves 28, completed 28, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
      === DDARing 1 ===
      Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.2
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is doing "G4 P500" in state(s) 0 0, running macro
      Aux2 is idle in state(s) 0
      File2 is idle in state(s) 0
      Queue2 is idle in state(s) 0
      Q0 segments left 0, axes/extruders owned 0x8000000f
      Code queue 0 is empty
      Code queue 1 is empty
      === Filament sensors ===
      check 0 clear 0
      Extruder 0: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
      Extruder 1: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
      Extruder 2: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
      Extruder 3: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
      === CAN ===
      Messages queued 13155, received 29867, lost 0, errs 0, boc 0
      Longest wait 1ms for reply type 6042, peak Tx sync delay 10, free buffers 50 (min 49), ts 7274/7273/0
      Tx timeouts 0,0,0,0,0,0
      === Network ===
      Slowest loop: 40.94ms; fastest: 0.03ms
      Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 1 of 8
      = Ethernet =
      Interface state: active
      Error counts: 0 0 0 1 0 0
      Socket states: 5 2 2 2 2 0 0 0
      === WiFi ===
      Interface state: disabled
      Module is disabled
      === Multicast handler ===
      Responder is inactive, messages received 0, responses 0
      • chrishammundefined
        chrishamm administrators @Diamondback
        @Diamondback Please share your filament unload.g/load.g/config.g files and all other macros that they call.
        Duet software engineer
        Diamondbackundefined 2 Replies Last reply Reply Quote 0
          Diamondback @chrishamm
          @chrishamm
          Actual filament files: (I've picked one specific filament, there are many more like this)
          load.g
          M98 P"/macros/FilamentConfig/PETG/load"
          unload.g
          M98 P"/macros/FilamentConfig/PETG/unload"
          config.g
          M98 P"/macros/FilamentConfig/PETG/config"
          Filament specific redirection layer: (Each filament type has its own set of macros with the same code but different parameters)
          /macros/FilamentConfig/PETG/load:
          M98 P"/macros/FilamentConfig/Generic/load" T230 S210 R150 F{global.pebbleFeedSpeedDefault}
          /macros/FilamentConfig/PETG/unload:
          M98 P"/macros/FilamentConfig/Generic/unload" T240
          /macros/FilamentConfig/PETG/config:
          M98 P"/macros/FilamentConfig/Generic/config" N"PETG - Generic"
          Generic macros:
          /macros/FilamentConfig/Generic/load:
          set global.toolheadDisplayState = "filamentLoad"
          var extrusionTemp = var.T
          var extrusionMinTemp = var.S
          var retractionMinTemp = var.R
          set global.pebbleFeedSpeed = var.F ;apply commanded pebble feed speed
          M98 P"/macros/Misc/Lights/On"
          M291 P"Heating for purge" R"Filament" S0 T5
          M98 P"/macros/Toolchanging/HomeIfNotHomed"
          var previousTemp = tools[state.currentTool].active[0]
          M568 P{state.currentTool} S{var.extrusionTemp} R0
          M116 P{state.currentTool}
          M302 S{var.extrusionMinTemp} R{var.retractionMinTemp}         	;Cold extrusion settings
          if move.axes[1].userPosition > 0 ;make sure we do not try to move to the purge location without being far away from the dock
              G90
              G1 Y0 F25000
          G1 X-70 F25000
          G1 Y-220 F25000
          M400
          M98 P"/macros/Misc/Beep"
          M291 P"Ready to feed new filament?" R"Filament Loading" S2
          var keepFeeding = true
          while var.keepFeeding == true
              G1 E300 F3000
              M400
              M291 S4 P"Filament loaded correctly?" R"Filament Loading" K{"Yes", "No, feed again"}
              if input == 0
                  set var.keepFeeding = false
          M98 P"/macros/Tool/Purge"
          M568 P{state.currentTool} S{var.previousTemp} R0
          set global.toolheadDisplayState = "idle"
          set global.deactivateToolAfterFilamentChange = true
          /macros/FilamentConfig/Generic/unload:
          set global.toolheadDisplayState = "filamentUnload"
          var releaseTemp = var.T
          M568 P{state.currentTool} S{var.releaseTemp} R0
          G91
          G1 E-10 F3000
          G4 S2
          G1 E-30 F10000
          M291 P"Ready to pull out filament?" R"Filament" S2
          G1 E-500 F5000
          G90
          M400
          /macros/FilamentConfig/Generic/config:
          if state.currentTool < 0
          	M99
          var pressureAdvance = 0
          var retractionDistance = 0.5
          var retractionSpeed = 2000
          var zHopDistance = 0
          var minExtrudeTemp = 180
          var pebbleFeedSpeed = global.pebbleFeedSpeedDefault
          var name = param.N
          var nozzleSize = global.toolNozzleSizes[state.currentTool]
          M98 P"/macros/FilamentConfig/Generic/GetFilamentSettingsWithNameAndSize" N{var.name} S{var.nozzleSize}
          if global.lastMacroResult == null
          	var errMsg = "Can't find filament settings for filament '" ^ var.name ^ "' and " ^ var.nozzleSize ^ "mm nozzle , falling back to defaults!"
          	echo {var.errMsg}
          	M291 P{var.errMsg} R"Filament Config" S2
          else
          	set var.pressureAdvance = global.lastMacroResult[0]
          	set var.retractionDistance = global.lastMacroResult[1]
          	set var.retractionSpeed = global.lastMacroResult[2]
          	set var.zHopDistance = global.lastMacroResult[3]
          	set var.minExtrudeTemp = global.lastMacroResult[4]
          	set var.pebbleFeedSpeed = global.lastMacroResult[5]
          var minRetractTemp = var.minExtrudeTemp - 30
          echo "Using filament settings: " ^ var.name ^ " with " ^ var.nozzleSize ^ "mm nozzle, Retraction: " ^ var.retractionDistance ^ "mm@" ^ var.retractionSpeed ^ "mm/min, Z-Hop: " ^ var.zHopDistance
          echo "PA: " ^ var.pressureAdvance ^ ", minimum extrusion temperature: " ^ var.minExtrudeTemp ^ ", pebble feed speed: " ^ var.pebbleFeedSpeed
          M207 S{var.retractionDistance} F{var.retractionSpeed} Z{var.zHopDistance} 	;retraction settings
          M572 D{tools[state.currentTool].extruders[0]} S{var.pressureAdvance} 		;pressure advance settings
          M302 S{var.minExtrudeTemp} R{var.minRetractTemp}							;cold extrusion settings
          set global.pebbleFeedSpeed = var.pebbleFeedSpeed 							;set pebble feed speed
          In order of appearance...
          /macros/Misc/Lights/On:
          M42 P1 S230
          /macros/Toolchanging/HomeIfNotHomed:
          if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed || !move.axes[3].homed
            echo "Not all axis homed, starting full homing process"
            G28
          /macros/Misc/Beep
          M300 S500 P400
          /macros/Tool/Purge:
          M98 P"/macros/Toolchanging/Wiper/PrimeBrush" R15
          G90
          M564 S1
          /macros/Toolchanging/Wiper/PrimeBrush:
          var primeRepeats = 4
          if exists(var.R)
          	set var.primeRepeats = var.R
          M98 P"/macros/Toolchanging/Wiper/PrimeBrushPebbleDisk" R{var.primeRepeats}
          /macros/Toolchanging/Wiper/PrimeBrushPebbleDisk:
          	echo "Can't Prime & Brush, no tool selected!"
          	M99
          var brushStartPositionX = -80
          var brushStartPositionY = -220
          var brushEndPositionX = -130
          var brushEndPositionY = -220
          var pebblePositionX = -151.0
          var pebblePositionY = -220.0
          var diskStep = 50
          var wiperHeightPurgeInitial = 20.6
          var wiperHeightPurgeBulk = var.wiperHeightPurgeInitial - 1.5
          var wiperHeightRotate = var.wiperHeightPurgeBulk - 2
          var wiperHeightIdle = var.wiperHeightPurgeInitial - 5
          var wiperHeightBrush = var.wiperHeightPurgeInitial + 0.5
          var wiperPurgeAmountPrime = 2
          var wiperPurgeAmountInitial = 2
          var wiperPurgeAmountBulk = 3
          var wiperHeightFeedrate = 3000
          	M99
          if heat.heaters[tools[state.currentTool].heaters[0]].current > heat.coldExtrudeTemperature
          	M106 S255
          	M564 S0
          	G90
          	G1 W{var.wiperHeightIdle} F{var.wiperHeightFeedrate}
          	G1 X{var.brushStartPositionX} Y{var.brushStartPositionY} F25000
          	G1 W{var.wiperHeightBrush} F{var.wiperHeightFeedrate}
          	G1 X{var.brushEndPositionX} Y{var.brushEndPositionY} F25000
          	G1 W{var.wiperHeightPurgeBulk} F{var.wiperHeightFeedrate}
          	G1 X{var.pebblePositionX} Y{var.pebblePositionY} F25000
          	var primeRepeats = 10
          	if exists(var.R)
          	while iterations < var.primeRepeats
          		G92 D0
          		M83
          		M106 S255
          		G90
          		G1 W{var.wiperHeightPurgeInitial} F5000
          		;G11
          		if iterations == 0
          			G1 E{var.wiperPurgeAmountPrime} F{global.pebbleFeedSpeed}
          		else
          			G0 E1 F3000
          		G1 E{var.wiperPurgeAmountInitial} F{global.pebbleFeedSpeed}
          		M106 S255
          		;G1 W{var.wiperHeightPurgeBulk} F5000
          		G1 W{var.wiperHeightPurgeBulk} E{var.wiperPurgeAmountBulk} F{global.pebbleFeedSpeed/7}
          		G4 P400
          		G0 E-1 F3000
          		;G10
          		G90
          		G92 D0
          		G1 W{var.wiperHeightRotate} D{var.diskStep} F10000
          		G91
          		;G1 D{var.diskStep} F20000
          		G90
          	G90
          	M106 S0
          	M564 S1
          else
          	echo "Skipping Prime & Brush due to unheated tool"
          /macros/FilamentConfig/Generic/GetFilamentSettingsWithNameAndSize:
          set global.lastMacroResult = null
          if !exists(param.N) || !exists(param.S)
          	M99
          var name = param.N
          var size = param.S
          while iterations < #global.filamentSettings
          	if global.filamentSettings[iterations][0] == var.name
          		var nozzleSizeId = -1
          		while iterations < #global.nozzleSizeMap
          			if global.nozzleSizeMap[iterations] == var.size
          				set var.nozzleSizeId = iterations
          		if var.nozzleSizeId >= 0
          			var settings = global.filamentSettings[iterations][1][var.nozzleSizeId]
          			set global.lastMacroResult = var.settings
          			M99
          		else
          			echo "Can't find nozzle size id for nozzle size: " ^ var.size
          			M99
          echo "Can't find filament settings for filament: " ^ var.name
          • Diamondbackundefined Diamondback marked this topic as a question
            @chrishamm Anything else I can help with?
              @Diamondback You certainly call a lot of different macros in there. Stack overflows typically occur if the nesting becomes too deep. Can you please attach a USB terminal to your Duet, run M111 P3 S1, and capture the output you get when you try to change the filament? That should make it easier for us to identify the underlying cause.
