    Help! Too little movement error
    Filament Monitor
    • Sgt G 294undefined
      Sgt G 294
      My printer ran fine with no issues for months and TONS of prints. Now I cannot get through a print without numerous errors.
      My current M591 settings:
      M591 D0 P3 C"e0stop" S1 R30:150 L24.84 E3.0
      M591 D0 (during print):
      Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 24.84mm/rev, allow 30% to 150%, check printing moves every 3.0mm, version 3, mag 131 agc 87, measured sensitivity 21.54mm/rev, min 87% max 105% over 786.1mm
      M591 D0 (after error/pausing print):
      Duet3D rotating magnet filament monitor v3 on pin e0stop, enabled, sensitivity 24.84mm/rev, allow 30% to 150%, check printing moves every 3.0mm, version 3, mag 132 agc 87, measured sensitivity 21.67mm/rev, min -1% max 106% over 1107.7mm
      I have changed nothing on the printer and have been using the same filament. It shows I have Duet Web Control version 3.4.0
      Thanks for your help!
        Has something worn down or gotten loose? slipped?
        • demonio669undefined
          demonio669
          Please Excuse my english
          Some tips:
          • Check filament flow rate is lower than the nozzle can handle . I have e3e Revo Micro and this page has useful:
          https://e3d-online.com/pages/revo-nozzle-maximum-flow-rates
          • Try to put the spool over bearings to minimize the pull the spool makes to the sensor
          • Check the sensor wheel is clean and if don´t cleanit by removing the plastic stuck in it
          • Check the extruder is not loosing steps
          • Check the extruder e-steps is correctly calibrated (if you send 100mm to extrude (G1 E100, you measure exactly 100mm )
