    Help - long print and getting too little movement error
    Filament Monitor
    330
    • charlesmcundefined
      charlesmc
      I'm on layer 249 of a 900 layer print. The print ran for hours, but got a too little movement error overnight and then that error has been increasing throughout the day. I just hit unpause each time to get the print going again.
      I had not used my 3D printer in a long time prior to a test print just before this larger print. I upgraded the firmware (Duet 3 mini 5) to 3.4.6 and I turned the filament sensor back on using the following command. I did not have issues with the test print and therefore thought that I was good to go with larger print.
      M591 D0 P3 C"io2.in" S2
      When I run M591 D0 in the console right now, I get:
      Duet3D rotating magnet filament monitor v3 on pin io2.in, enabled, sensitivity 28.80mm/rev, allow 60% to 160%, check printing moves every 3.0mm, version 3, mag 131 agc 87, measured sensitivity 24.93mm/rev, min 97% max 103% over 534.4mm
      Can I send another M591 D0 P3 C"io2.in" S2 L20:200 command through the console to update the filament monitor setting while the print is running? Or is that going to derail things?
      Thanks for your help!
      • fcwiltundefined
        fcwilt @charlesmc
        @charlesmc
        Try it without the P, C or S parameters.
        I don't know for sure it will be OK so you may wish to check with @dc42.
          charlesmc
          Just sent M591 D0 L30:200
          Just got back...so that didn't update it
          	M591 D0
          Duet3D rotating magnet filament monitor v3 on pin io2.in, enabled, sensitivity 30.00mm/rev, allow 60% to 160%, check printing moves every 3.0mm, version 3, mag 132 agc 87, measured sensitivity 24.93mm/rev, min 97% max 103% over 2113.6mm
          • fcwiltundefined
            fcwilt @charlesmc
            @charlesmc
            I cannot find the docs discussing where L has two values as you are using.
            The sensitivity report back was different going from 28.80 to 30.00.
            What are you trying to change?
              charlesmc
              Ack...I screwed up the command that I posted above. I just sent a new command down and it correctly updated the range to 30% to 200%.
              M591 D0 P3 c"io2.in" L28.4 R30:200
              fcwiltundefined 1 Reply Last reply Reply Quote 1
              • fcwiltundefined
                fcwilt @charlesmc
                @charlesmc
                Hopefully your print will now finish without stopping.
                  charlesmc
                  I ended up sending
                  M591 D0 P3 C"io2.in" L24.93 R30:200 S1 A0
                  However, I'm still periodically getting too little movement errors. Looks like I'm dipping down below 30%. In the below instance, I caught the system dipping down to 48%.
                  Duet3D rotating magnet filament monitor v3 on pin io2.in, enabled, sensitivity 24.93mm/rev, allow 30% to 200%, check printing moves every 3.0mm, version 3, mag 132 agc 87, measured sensitivity 24.98mm/rev, min 48% max 103% over 816.4mm
                  My whole objective with the filament monitor is to just detect the end of the spool, so that the system can pause, I can load up more filament, and keep on going.
                  But it has too many false positives to be useful.
                  • fcwiltundefined
                    fcwilt @charlesmc
                    @charlesmc
                    I tried that kind but was not in the mood to get it "fine tuned" - so I just installed a simple TriangleLab's unit which is just a microswitch mounted in a nice little case with status LEDs.
                    TL Filament Runout Sensor
                      charlesmc
                      Triangle sensor ordered thanks!
