    Magnet too strong error message with Duet V3 filament sensor
    Filament Monitor
    1
    • jer1001undefined
      jer1001
      Hi I would like to know what is the distance between the magnet and the sensor on the V4 filament sensor should be. The housing designed by Lo-fi gives an error of magnet too strong. The standard housing is working fine but there is a little more filament resistance. If I know the optimum distance I may modify the Lo-fi housing to deal with the change in magnet of the new version (V4) Anyway if someone knows the dimension it would make things very simple. Many thanks Jeremy
      jer1001undefined 1 Reply Last reply Reply Quote 0
      • jer1001undefined
        jer1001 @jer1001
        @jer1001 Sorry I should have said V3
