Archive of release candidates
Hi all. Is there an archive of release candidates anywhere? It looks like they have been removed from GitHub. I am specifically looking for 3.2-RC2. That seems to be the last version of the firmware that worked for me without layer shifting. I am trying to load that firmware again to compare to 3.2 and newer to see if the shifting goes away. I have two boards and both have this issue. Before I updated the second one from 3.2-RC2 to the latest, it worked perfectly. Thanks all! Hopefully I can figure out what I am doing wrong and get this fixed.
@cbusillo we remove unsupported releases (i.e. betas and release candidates) when the corresponding stable release has been out for a while. However, the tags for them are still present in Github so it is possible to build them from the source code.
Thank you both! It turned out to be the change in the M593, input shaping. The discord helped me figure that one out. I didn't realize the old algorithm was not in the new firmware. I have an accelerometer coming so I can really tune it now. thank you both for the great hardware/software.
undefined cbusillo marked this topic as a question
undefined cbusillo has marked this topic as solved
