Duet 2 to Duet 3hc mainboard, x axis running mirrored
Hello I am in need of help.
I am setting up the stronghold pro with the duet 3hc board.
The settings are imported from a duet 2 running an ooznest workbee. This machine homed to the back right and the new machine is the back left.
The problem is the x axis is inverted/flipped and is running effectivly mirrored and I need help flipping it.
It homes fine to the limit switch but when I test a file created in fusion 360 it runs flipped on the x axis.
I need poiniting to which settings to adjust, im sure its somthing to do with the homing and how the coordinates are set but would like confirmation before changing a million numbers and hoping for the best.
@kernelcnc best to attach your homing files along with your config for people to look at and help
