Failed to build DWC
@azs123 one for @chrishamm
@azs123 What DWC version/branch are you trying to build?
@chrishamm 3.4.6
@azs123 Did you run
npm install
prior tonpm run build
? Before you can build it, you also need to set an environment variable for 3.4.6 as described here: https://github.com/Duet3D/DuetWebControl#project-setup -
@chrishamm I did all the steps described in project-setup.
I need to runnpm install --legacy-peer-deps
in order to run it succesfully, dont know if this can cause an issue. -
@azs123 Update: I used linux to build DWC and it worked like a charm.
