    Pendant 4th axis output in "U"
    Config Tool
    1
    1
    166
    • Phil Tundefined
      Phil T
      Hi Guys,
      I've just wired and installed a 4 axis pendant controller on my CNC router.
      I followed the Duet3d pendant documentation to the letter.
      The documentation was easy to understand and follow, excellent job!
      My router is controlled by a Duet2 3d WIFI board using firmware 3.3 - works a treat!
      The board controls a VFD spindle, a Diode laser and a 4th rotary axis with no issues.
      Pendant.
      The pendant works on X,Y & Z axis but would not work on the 4th axis.
      After looking through the Arduino software, I found that the 4th axis was programmed as "U" but my machine is setup to use "A" as the 4th rotary axis.
      I created a trial "U" axis in my config file by coping my current "A" axis details.
      The pendant 4th rotary axis works a treat but unfortunately, doesn't synchronize with my " A" axis. This could cause a problem if I use both letter controls, ongoing.
      The post processors I use are setup to post "A" as the rotary axis.
      Could you please advise:
      1. Is there is a way of changing "U" axis within the software to output "A" either on the Arduino side or within the Duet config. g
      2. Which part of the Arduino or Duet software can I alter to smooth out, "fine tune" the axis movement when using the pendant. - the feed rate controlled by X10 to X100 is very fast.
      I could alter the post processors to output "U" and remove the "A" axis as a fall back solution.
      Any help would be greatly appreciated.
      Phil T
