    custom_http_endpoint.py example - http error 500?
    DSF Development
    • oozeBotundefined
      oozeBot
      @chrishamm @Falcounet
      We are evaluating the custom_http_endpoint.py example located at
      https://github.com/Duet3D/dsf-python/blob/main/examples/custom_http_endpoint.py. We are running dsf-python-3.4.6.post4. The example is returning a 500 error and we are unsure how to debug it to move past it. Here is the output from the console while running:
      send: {"mode":"Command","version":12}
      recv: {"success":true}
      send: {"command":"AddHttpEndpoint","EndpointType":"GET","Namespace":"custom","Path":"getIt","IsUploadRequest":false}
      recv: {"result":"/run/dsf/custom/getIt-GET.sock","success":true}
      Try accessing http://duet3.local/machine/custom/getIt in your browser...
      Any thoughts on what might be wrong? Thanks in advance.
      • oozeBotundefined
        oozeBot
        Bump.. So far I have not been able to find any logging or details on why it is returning a 500 error. Note that any invalid URL returns 404, so DSF is picking up that it's been registered.
        Maybe the example is from a previous version of dsf-python and needs updating? Please advise as we do have a use for this and are quite motivated to put it into practice. Thanks
        • oozeBotundefined oozeBot marked this topic as a question
        • chrishammundefined
          chrishamm administrators @oozeBot
          @oozeBot Are you running this script as root or as a user that is not part of the dsf group? To debug this problem, you'd have to look in the duetwebserver journalctl log, which generates a message when it fails to access your custom HTTP endpoint.
          If you run it as root, you need to change the ownership of the corresponding socket file (/run/dsf/custom/getIt-GET.sock) to dsf before the web server (running as dsf user) can access it.
          Duet software engineer
          oozeBotundefined 1 Reply Last reply Reply Quote 0
          • oozeBotundefined
            oozeBot @chrishamm
            @chrishamm Thanks! That’s the nudge we needed- It’s definitely a permission issue. We’ll get it sorted.
            • oozeBotundefined oozeBot has marked this topic as solved
