    3.5.0rc3 DSF won't connect to Duet board
    Beta Firmware
    386
    • katiepi1066undefined
      katiepi1066
      I haven't ruled out this is user error but I can't figure where I'm going wrong.
      Hardware is known good.
      DSF works when using the stable branch.
      I upgrade to unstable and update the pi side, everything works fine until it tries to update the board. It thinks the firmware flash works, but the board never comes back up.
      I use bossa to manually flash to 3.5.0rc3. Bossa thinks it flashes successfully but no joy on the DSF side.
      I nuke the card and reimage it, and bossa reflash the board to 3.4.6. Run the linux updates (still on the stable branch). Everything's happy, DSF connects no problem.
      I switch back to unstable and run the linux updates again. Double check that it's pulling 3.5.0rc3 and it is. Update tries to flash the board and it fails with errors when running apt dist-upgrade.
      I use Bossa to reflash 3.5.0rc3. Bossa thinks it works but again, no DSF joy.
      I've reviewed the release notes and everything else I can find and I can't figure out what I'm missing. Help?
      EDIT - and yes I am BOSSA flashing the SBC builds not the standard firmware.
      • chrishammundefined
        chrishamm administrators @katiepi1066
        @katiepi1066 What do you get in the journal of duetcontrolserver? Run journalctl -u duetcontrolserver -ef on the Pi and check what comes up.
        Duet software engineer
        katiepi1066undefined 1 Reply Last reply Reply Quote 0
          katiepi1066
          Figured it out - Needed to be using the latest OS image (bookwork), not the old stable image.
          • printerguy3dundefined
            printerguy3d
            doesn't like to run on duet2 ethernet board in sbc mode here is putty response from journalctl
            rface.ProcessPacket(PacketHeader packet) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 970
            Feb 16 11:01:19 duet3 DuetControlServer[11300]: at DuetControlServer.SPI.Interface.Run() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 772
            Feb 16 11:01:19 duet3 DuetControlServer[11300]: at DuetControlServer.Utility.PriorityThreadRunner.<>c__DisplayClass0_0.<Start>b__0() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Utility/PriorityThreadRunner.cs:line 25
            Feb 16 11:01:19 duet3 DuetControlServer[11300]: [info] Application has shut down
            Feb 16 11:01:19 duet3 systemd[1]: duetcontrolserver.service: Main process exited, code=exited, status=70/SOFTWARE
            Feb 16 11:01:19 duet3 systemd[1]: duetcontrolserver.service: Failed with result 'exit-code'.
            Feb 16 11:01:19 duet3 systemd[1]: duetcontrolserver.service: Consumed 3.165s CPU time.
            Feb 16 11:01:24 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 112.
            Feb 16 11:01:24 duet3 systemd[1]: Stopped duetcontrolserver.service - Duet Control Server.
            Feb 16 11:01:24 duet3 systemd[1]: duetcontrolserver.service: Consumed 3.165s CPU time.
            Feb 16 11:01:24 duet3 systemd[1]: Starting duetcontrolserver.service - Duet Control Server...
            Feb 16 11:01:24 duet3 DuetControlServer[11382]: Duet Control Server v3.5.0-rc.3
            Feb 16 11:01:24 duet3 DuetControlServer[11382]: Written by Christian Hammacher for Duet3D
            Feb 16 11:01:24 duet3 DuetControlServer[11382]: Licensed under the terms of the GNU Public License Version 3
            Feb 16 11:01:25 duet3 DuetControlServer[11382]: [info] Settings loaded
            Feb 16 11:01:26 duet3 DuetControlServer[11382]: [info] Environment initialized
            Feb 16 11:01:26 duet3 DuetControlServer[11382]: [info] Connection to Duet established
            Feb 16 11:01:26 duet3 DuetControlServer[11382]: [info] IPC socket created at /run/dsf/dcs.sock
            Feb 16 11:01:26 duet3 systemd[1]: Started duetcontrolserver.service - Duet Control Server.
            Feb 16 11:01:26 duet3 DuetControlServer[11382]: [fatal] Abnormal program termination
            Feb 16 11:01:26 duet3 DuetControlServer[11382]: [fatal] SPI task faulted
            Feb 16 11:01:26 duet3 DuetControlServer[11382]: System.InvalidOperationException: Stack underrun on channel File2
            Feb 16 11:01:26 duet3 DuetControlServer[11382]: at DuetControlServer.SPI.Channel.Processor.Pop() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Channel/Processor.cs:line 128
            Feb 16 11:01:26 duet3 DuetControlServer[11382]: at DuetControlServer.SPI.Channel.Processor.MacroFileClosed() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Channel/Processor.cs:line 1121
            Feb 16 11:01:26 duet3 DuetControlServer[11382]: at DuetControlServer.SPI.Interface.HandleMacroFileClosed() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 1321
            Feb 16 11:01:26 duet3 DuetControlServer[11382]: at DuetControlServer.SPI.Interface.ProcessPacket(PacketHeader packet) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 970
            Feb 16 11:01:26 duet3 DuetControlServer[11382]: at DuetControlServer.SPI.Interface.Run() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 772
            Feb 16 11:01:26 duet3 DuetControlServer[11382]: at DuetControlServer.Utility.PriorityThreadRunner.<>c__DisplayClass0_0.<Start>b__0() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Utility/PriorityThreadRunner.cs:line 25
            Feb 16 11:01:26 duet3 DuetControlServer[11382]: [info] Application has shut down
            Feb 16 11:01:27 duet3 systemd[1]: duetcontrolserver.service: Main process exited, code=exited, status=70/SOFTWARE
            Feb 16 11:01:27 duet3 systemd[1]: duetcontrolserver.service: Failed with result 'exit-code'.
            Feb 16 11:01:27 duet3 systemd[1]: duetcontrolserver.service: Consumed 3.220s CPU time.
            Feb 16 11:01:32 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 113.
            Feb 16 11:01:32 duet3 systemd[1]: Stopped duetcontrolserver.service - Duet Control Server.
            Feb 16 11:01:32 duet3 systemd[1]: duetcontrolserver.service: Consumed 3.220s CPU time.
            Feb 16 11:01:32 duet3 systemd[1]: Starting duetcontrolserver.service - Duet Control Server...
            Feb 16 11:01:32 duet3 DuetControlServer[11461]: Duet Control Server v3.5.0-rc.3
            Feb 16 11:01:32 duet3 DuetControlServer[11461]: Written by Christian Hammacher for Duet3D
            Feb 16 11:01:32 duet3 DuetControlServer[11461]: Licensed under the terms of the GNU Public License Version 3
            Feb 16 11:01:33 duet3 DuetControlServer[11461]: [info] Settings loaded
            Feb 16 11:01:34 duet3 DuetControlServer[11461]: [info] Environment initialized
            Feb 16 11:01:34 duet3 DuetControlServer[11461]: [info] Connection to Duet established
            Feb 16 11:01:34 duet3 DuetControlServer[11461]: [info] IPC socket created at /run/dsf/dcs.sock
            Feb 16 11:01:34 duet3 systemd[1]: Started duetcontrolserver.service - Duet Control Server.
            Feb 16 11:01:34 duet3 DuetControlServer[11461]: [fatal] Abnormal program termination
            Feb 16 11:01:34 duet3 DuetControlServer[11461]: [fatal] SPI task faulted
            Feb 16 11:01:34 duet3 DuetControlServer[11461]: System.InvalidOperationException: Stack underrun on channel File2
            Feb 16 11:01:34 duet3 DuetControlServer[11461]: at DuetControlServer.SPI.Channel.Processor.Pop() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Channel/Processor.cs:line 128
            Feb 16 11:01:34 duet3 DuetControlServer[11461]: at DuetControlServer.SPI.Channel.Processor.MacroFileClosed() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Channel/Processor.cs:line 1121
            Feb 16 11:01:34 duet3 DuetControlServer[11461]: at DuetControlServer.SPI.Interface.HandleMacroFileClosed() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 1321
            Feb 16 11:01:34 duet3 DuetControlServer[11461]: at DuetControlServer.SPI.Interface.ProcessPacket(PacketHeader packet) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 970
            Feb 16 11:01:34 duet3 DuetControlServer[11461]: at DuetControlServer.SPI.Interface.Run() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 772
            Feb 16 11:01:34 duet3 DuetControlServer[11461]: at DuetControlServer.Utility.PriorityThreadRunner.<>c__DisplayClass0_0.<Start>b__0() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Utility/PriorityThreadRunner.cs:line 25
            Feb 16 11:01:35 duet3 DuetControlServer[11461]: [info] Application has shut down
            Feb 16 11:01:35 duet3 systemd[1]: duetcontrolserver.service: Main process exited, code=exited, status=70/SOFTWARE
            Feb 16 11:01:35 duet3 systemd[1]: duetcontrolserver.service: Failed with result 'exit-code'.
            Feb 16 11:01:35 duet3 systemd[1]: duetcontrolserver.service: Consumed 3.838s CPU time.
            Feb 16 11:01:40 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 114.
            Feb 16 11:01:40 duet3 systemd[1]: Stopped duetcontrolserver.service - Duet Control Server.
            Feb 16 11:01:40 duet3 systemd[1]: duetcontrolserver.service: Consumed 3.838s CPU time.
            Feb 16 11:01:40 duet3 systemd[1]: Starting duetcontrolserver.service - Duet Control Server...
            Feb 16 11:01:41 duet3 DuetControlServer[11559]: Duet Control Server v3.5.0-rc.3
            Feb 16 11:01:41 duet3 DuetControlServer[11559]: Written by Christian Hammacher for Duet3D
            Feb 16 11:01:41 duet3 DuetControlServer[11559]: Licensed under the terms of the GNU Public License Version 3
            Feb 16 11:01:42 duet3 DuetControlServer[11559]: [info] Settings loaded
            Feb 16 11:01:42 duet3 DuetControlServer[11559]: [info] Environment initialized
            Feb 16 11:01:42 duet3 DuetControlServer[11559]: [info] Connection to Duet established
            Feb 16 11:01:42 duet3 DuetControlServer[11559]: [info] IPC socket created at /run/dsf/dcs.sock
            Feb 16 11:01:42 duet3 systemd[1]: Started duetcontrolserver.service - Duet Control Server.
            Feb 16 11:01:43 duet3 DuetControlServer[11559]: [fatal] Abnormal program termination
            Feb 16 11:01:43 duet3 DuetControlServer[11559]: [fatal] SPI task faulted
            Feb 16 11:01:43 duet3 DuetControlServer[11559]: System.InvalidOperationException: Stack underrun on channel File2
            Feb 16 11:01:43 duet3 DuetControlServer[11559]: at DuetControlServer.SPI.Channel.Processor.Pop() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Channel/Processor.cs:line 128
            Feb 16 11:01:43 duet3 DuetControlServer[11559]: at DuetControlServer.SPI.Channel.Processor.MacroFileClosed() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Channel/Processor.cs:line 1121
            Feb 16 11:01:43 duet3 DuetControlServer[11559]: at DuetControlServer.SPI.Interface.HandleMacroFileClosed() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 1321
            Feb 16 11:01:43 duet3 DuetControlServer[11559]: at DuetControlServer.SPI.Interface.ProcessPacket(PacketHeader packet) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 970
            Feb 16 11:01:43 duet3 DuetControlServer[11559]: at DuetControlServer.SPI.Interface.Run() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 772
            Feb 16 11:01:43 duet3 DuetControlServer[11559]: at DuetControlServer.Utility.PriorityThreadRunner.<>c__DisplayClass0_0.<Start>b__0() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Utility/PriorityThreadRunner.cs:line 25
            Feb 16 11:01:43 duet3 DuetControlServer[11559]: [info] Application has shut down
            Feb 16 11:01:43 duet3 systemd[1]: duetcontrolserver.service: Main process exited, code=exited, status=70/SOFTWARE
            Feb 16 11:01:43 duet3 systemd[1]: duetcontrolserver.service: Failed with result 'exit-code'.
            Feb 16 11:01:43 duet3 systemd[1]: duetcontrolserver.service: Consumed 3.238s CPU time.
            Feb 16 11:01:48 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart
            F
              printerguy3d
              counter is at 115.
              Feb 16 11:01:48 duet3 systemd[1]: Stopped duetcontrolserver.service - Duet Control Server.
              Feb 16 11:01:48 duet3 systemd[1]: duetcontrolserver.service: Consumed 3.238s CPU time.
              Feb 16 11:01:48 duet3 systemd[1]: Starting duetcontrolserver.service - Duet Control Server...
              Feb 16 11:01:49 duet3 DuetControlServer[11638]: Duet Control Server v3.5.0-rc.3
              Feb 16 11:01:49 duet3 DuetControlServer[11638]: Written by Christian Hammacher for Duet3D
              Feb 16 11:01:49 duet3 DuetControlServer[11638]: Licensed under the terms of the GNU Public License Version 3
              Feb 16 11:01:49 duet3 DuetControlServer[11638]: [info] Settings loaded
              Feb 16 11:01:50 duet3 DuetControlServer[11638]: [info] Environment initialized
              Feb 16 11:01:50 duet3 DuetControlServer[11638]: [info] Connection to Duet established
              Feb 16 11:01:50 duet3 DuetControlServer[11638]: [info] IPC socket created at /run/dsf/dcs.sock
              Feb 16 11:01:50 duet3 systemd[1]: Started duetcontrolserver.service - Duet Control Server.
              Feb 16 11:01:50 duet3 DuetControlServer[11638]: [fatal] Abnormal program termination
              Feb 16 11:01:51 duet3 DuetControlServer[11638]: [fatal] SPI task faulted
              Feb 16 11:01:51 duet3 DuetControlServer[11638]: System.InvalidOperationException: Stack underrun on channel File2
              Feb 16 11:01:51 duet3 DuetControlServer[11638]: at DuetControlServer.SPI.Channel.Processor.Pop() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Channel/Processor.cs:line 128
              Feb 16 11:01:51 duet3 DuetControlServer[11638]: at DuetControlServer.SPI.Channel.Processor.MacroFileClosed() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Channel/Processor.cs:line 1121
              Feb 16 11:01:51 duet3 DuetControlServer[11638]: at DuetControlServer.SPI.Interface.HandleMacroFileClosed() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 1321
              Feb 16 11:01:51 duet3 DuetControlServer[11638]: at DuetControlServer.SPI.Interface.ProcessPacket(PacketHeader packet) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 970
              Feb 16 11:01:51 duet3 DuetControlServer[11638]: at DuetControlServer.SPI.Interface.Run() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 772
              Feb 16 11:01:51 duet3 DuetControlServer[11638]: at DuetControlServer.Utility.PriorityThreadRunner.<>c__DisplayClass0_0.<Start>b__0() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Utility/PriorityThreadRunner.cs:line 25
              Feb 16 11:01:51 duet3 DuetControlServer[11638]: [info] Application has shut down
              Feb 16 11:01:51 duet3 systemd[1]: duetcontrolserver.service: Main process exited, code=exited, status=70/SOFTWARE
              Feb 16 11:01:51 duet3 systemd[1]: duetcontrolserver.service: Failed with result 'exit-code'.
              Feb 16 11:01:51 duet3 systemd[1]: duetcontrolserver.service: Consumed 3.190s CPU time.
              Feb 16 11:01:56 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 116.
              Feb 16 11:01:56 duet3 systemd[1]: Stopped duetcontrolserver.service - Duet Control Server.
              Feb 16 11:01:56 duet3 systemd[1]: duetcontrolserver.service: Consumed 3.190s CPU time.
              Feb 16 11:01:56 duet3 systemd[1]: Starting duetcontrolserver.service - Duet Control Server...
              Feb 16 11:01:56 duet3 DuetControlServer[11717]: Duet Control Server v3.5.0-rc.3
              Feb 16 11:01:56 duet3 DuetControlServer[11717]: Written by Christian Hammacher for Duet3D
              Feb 16 11:01:56 duet3 DuetControlServer[11717]: Licensed under the terms of the GNU Public License Version 3
              Feb 16 11:01:57 duet3 DuetControlServer[11717]: [info] Settings loaded
              Feb 16 11:01:58 duet3 DuetControlServer[11717]: [info] Environment initialized
              Feb 16 11:01:58 duet3 DuetControlServer[11717]: [info] Connection to Duet established
              Feb 16 11:01:58 duet3 DuetControlServer[11717]: [info] IPC socket created at /run/dsf/dcs.sock
              Feb 16 11:01:58 duet3 systemd[1]: Started duetcontrolserver.service - Duet Control Server.
              Feb 16 11:01:58 duet3 DuetControlServer[11717]: [fatal] Abnormal program termination
              Feb 16 11:01:58 duet3 DuetControlServer[11717]: [fatal] SPI task faulted
              Feb 16 11:01:58 duet3 DuetControlServer[11717]: System.InvalidOperationException: Stack underrun on channel File2
              Feb 16 11:01:58 duet3 DuetControlServer[11717]: at DuetControlServer.SPI.Channel.Processor.Pop() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Channel/Processor.cs:line 128
              Feb 16 11:01:58 duet3 DuetControlServer[11717]: at DuetControlServer.SPI.Channel.Processor.MacroFileClosed() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Channel/Processor.cs:line 1121
              Feb 16 11:01:58 duet3 DuetControlServer[11717]: at DuetControlServer.SPI.Interface.HandleMacroFileClosed() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 1321
              Feb 16 11:01:58 duet3 DuetControlServer[11717]: at DuetControlServer.SPI.Interface.ProcessPacket(PacketHeader packet) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 970
              Feb 16 11:01:58 duet3 DuetControlServer[11717]: at DuetControlServer.SPI.Interface.Run() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 772
              Feb 16 11:01:58 duet3 DuetControlServer[11717]: at DuetControlServer.Utility.PriorityThreadRunner.<>c__DisplayClass0_0.<Start>b__0() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Utility/PriorityThreadRunner.cs:line 25
              Feb 16 11:01:58 duet3 DuetControlServer[11717]: [info] Application has shut down
              Feb 16 11:01:59 duet3 systemd[1]: duetcontrolserver.service: Main process exited, code=exited, status=70/SOFTWARE
              Feb 16 11:01:59 duet3 systemd[1]: duetcontrolserver.service: Failed with result 'exit-code'.
                katiepi1066 @chrishamm
                @chrishamm
                Feb 18 14:40:14 duet3 systemd[1]: Starting duetcontrolserver.service - Duet Control Server...
                Feb 18 14:40:15 duet3 DuetControlServer[2666]: Duet Control Server v3.5.0-rc.3
                Feb 18 14:40:15 duet3 DuetControlServer[2666]: Written by Christian Hammacher for Duet3D
                Feb 18 14:40:15 duet3 DuetControlServer[2666]: Licensed under the terms of the GNU Public License Version 3
                Feb 18 14:40:16 duet3 DuetControlServer[2666]: [info] Settings loaded
                Feb 18 14:40:16 duet3 DuetControlServer[2666]: [info] Environment initialized
                Feb 18 14:40:16 duet3 DuetControlServer[2666]: [info] Connection to Duet established
                Feb 18 14:40:16 duet3 DuetControlServer[2666]: [info] IPC socket created at /run/dsf/dcs.sock
                Feb 18 14:40:16 duet3 systemd[1]: Started duetcontrolserver.service - Duet Control Server.
                Feb 18 14:40:17 duet3 DuetControlServer[2666]: [fatal] Abnormal program termination
                Feb 18 14:40:17 duet3 DuetControlServer[2666]: [fatal] SPI task faulted
                Feb 18 14:40:17 duet3 DuetControlServer[2666]:    System.InvalidOperationException: Stack underrun on channel File2
                Feb 18 14:40:17 duet3 DuetControlServer[2666]:    at DuetControlServer.SPI.Channel.Processor.Pop() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Channel/Processor.cs:line 128
                Feb 18 14:40:17 duet3 DuetControlServer[2666]:    at DuetControlServer.SPI.Channel.Processor.MacroFileClosed() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Channel/Processor.cs:line 1121
                Feb 18 14:40:17 duet3 DuetControlServer[2666]:    at DuetControlServer.SPI.Interface.HandleMacroFileClosed() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 1321
                Feb 18 14:40:17 duet3 DuetControlServer[2666]:    at DuetControlServer.SPI.Interface.ProcessPacket(PacketHeader packet) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 970
                Feb 18 14:40:17 duet3 DuetControlServer[2666]:    at DuetControlServer.SPI.Interface.Run() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 772
                Feb 18 14:40:17 duet3 DuetControlServer[2666]:    at DuetControlServer.Utility.PriorityThreadRunner.<>c__DisplayClass0_0.<Start>b__0() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Utility/PriorityThreadRunner.cs:line 25
                Feb 18 14:40:17 duet3 DuetControlServer[2666]: [info] Application has shut down
                Feb 18 14:40:17 duet3 systemd[1]: duetcontrolserver.service: Main process exited, code=exited, status=70/SOFTWARE
                Feb 18 14:40:17 duet3 systemd[1]: duetcontrolserver.service: Failed with result 'exit-code'.
                Feb 18 14:40:17 duet3 systemd[1]: duetcontrolserver.service: Consumed 4.124s CPU time.
                Also updating the newest build did not in fact fix this issue.
                  @katiepi1066 Are you certain that you have RRF 3.5.0rc3 on the Duet 2 in SBC mode? File2 is NOT supported on that board, so I can't see why RRF would request macros to be closed on that particular channel.
                    @chrishamm I am as sure as I can be. I've flashed the board 2 ways:
                    1. Put 3.4.6 on the board with BOSSA. DWC tells me there's a file incompatibility and I need to update the board. I run M997 S0 to do so. Board goes down and never reconnects even after a power cycle
                    2. Manually flash 3.5.0rc3 SBC from the git repo onto the board using BOSSA. BOSSA thinks the board flashes correctly, but when powered on DWC is never able to connect to the board.
                    If there's another technique or something I'm missing I'm happy to try it.
                      @katiepi1066 Thanks for reporting this, I've got some bug fixes ready. We'll get back to you shortly.
                        printerguy3d
                        ready to test when you have something to try
