    Object Model Documentation : questions about fields
    Documentation
    • rakupicundefined
      rakupic
      Hello. Could you please finish the below sentence from the Object Model documentation?
      "state.msUpTime
      Millisecond fraction of [missing]"
      Also, the fans[].thermostatic.heaters[] field needs to be replaced by fans[].thermostatic.sensors[], doesn't it?
      droftartsundefined chrishammundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @rakupic
        @rakupic One for @chrishamm
        • chrishammundefined
          chrishamm administrators @rakupic
          @rakupic Thanks, I have fixed the documentation generator. It should be "Millsecond fraction of upTime", the generator tool didn't process <see cref="..." /> links correctly.
          fans[].thermostatic.heaters[] is valid in RRF 3.4 but deprecated in 3.5. I expect it to be removed in v3.6.
          Duet software engineer
