    Heat bed turning on too early on 3.5.0-rc3
    Beta Firmware
    • wschadowundefined
      wschadow
      When starting a print start.g is executed and basically doing homing and calling bed.g, where the true mesh bed leveling is done. In 3.5.0-rc3 the heatbed is tuning on already at this point. It looks like part of the print gcode is executed already, while startt.g / bed.g are still running.
      This happens on Duet3Mini5+ and Duet2. I checked 3.4.6 as well which works correctly.
        dc42 administrators @wschadow
        @wschadow I think you will find this is fixed in the latest 3.5 firmware at https://www.dropbox.com/scl/fo/yzchzlyxmxlzywjawqflu/h?rlkey=tl7dfs75yozhfgpze0jnkn32n&dl=0.
        wschadowundefined 2 Replies Last reply Reply Quote 0
        • wschadowundefined
          wschadow @dc42
          @dc42 thanks, for the quick fix, tested on two machines.
          • wschadowundefined
            wschadow @dc42
            @dc42 I noticed some other strange thing, which is maybe related: my start.g and bed.g turn the heaters off via
            M568 P0 S0 R0 A0                                                       ; turn tool 0 off
            M568 P1 S0 R0 A0                                                       ; turn tool 1 off
            M568 P2 S0 R0 A0                                                       ; turn tool 2 off
            and the beginning. No other temperature related settings. When starting the print on 3.4.6 I see
            while true meshbed leveling: This happens in 3.5.0-rc3+4 as well. On 3.5.0-rc3+4 even after the print I can see
            c0369491-c483-49ed-805d-b24c797912f5-image.png . My stop.g contains the lines
            as well.
              @wschadow I suspect DWC is reporting the tool state, not the heater state. The tool state is copied to the heater state when you release the tool or switch to the tool, but you can subsequently override it using M568, until the tool is next selected or freed.
