Firmware 1.20 issue
Upgraded to the new firmware 1.20 in an attempt to see if the massive AJAX errors I have in 1.19.2 would be cured.
Instead I had a new issue: the Z probe does not stop the homing at all, it did in 1.19.2 and 1.18.2.
I run a CoreXY setup, and when I reverted back to 1.19.2 the probe works just fine.
in 1.20 I tested the input status via 119 and it reported the probe as triggered but during homing it ignored it completely.- If you currently have G31 parameters for your active Z probe in config-override.g that are different from the ones in config.g, you should copy them to config.g, otherwise they will be lost next time you run M500.
I do not have a config-override.g file, but apart from that I don't quite see why it should completely ignore the probe…
a copy of the settings in 1.19.2:
M111 S0 ; Debugging off
G21 ; Work in millimetres
M555 P2 ; Set firmware compatibility to look like MarlinM667 S1 ; Select CoreXY mode
M208 X300 Y300 Z295 S0 ; Set axis maxima; Endstops
M574 X1 Y1 Z0 S0 ; Define active low and unused microswitches
M558 P3 X0 Y0 Z1 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
G31 P250 X16 Y30 Z0.5 ; Set Z probe trigger value, offset and trigger height
M557 X15:285 Y15:285 S20 ; Define mesh grid
What is in your homeg.g and homeall.g files? I suspect you have them set up for an endstop switch instead of for a Z probe. See https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Homing_Z.
dc42, they are unchanged in both firmwares.
but I can post them if you like:
homeall.g:; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool on Sun Jun 18 2017 15:09:50 GMT+0200 (Vest-Europa (sommertid))G91 ; Relative positioning
G1 Z5 F6000 ; Lift Z by 5mm
G1 S1 X-305 Y-305 F3000 ; course home X or Y
G1 S1 X-305 ; course home X
G1 S1 Y-305 ; course home Y
G1 X5 Y8 F600 ; move away from the endstops
G1 S1 X-10 ; fine home X
G1 S1 Y-10 ; fine home Y
G1 Z-300 F1800 S1 ; Move Z down until the switch triggersG90 ; Absolute positioning
; Tell the firmware where we are
G92 Z0.5; Uncomment the following line to lift the nozzle after probing
;G1 Z1 F100Homez.g:
; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool on Sun Jun 18 2017 15:09:50 GMT+0200 (Vest-Europa (sommertid)); Lift Z relatively to current position
G91
G1 Z5 F6000; Move Z down until the switch triggers
G1 Z-300 S1 F1800; Back to absolute positioning
G90; Tell the firmware where we are
G92 Z0.5; Uncomment the following lines to lift Z after probing
;G91
;G1 Z1 F100
;G90
As I thought. You should use G30 commands instead of G1 S1 and G92 commands, see the wiki link I posted.
threw the whole config out the window and started all over, worked alot better.
still had tons of wifi disconnects though, strangely they stopped immidiatly when I disconnected the LCD display
