    How to assign a value to a node? Or: Error: expected '='
    Gcode meta commands
    • DavidG_68kg_PLAundefined
      DavidG_68kg_PLA
      How can I reset my extrusion factor via a macro (prior to the print start)?
      My macro looks as follows:
      if move.extruders[0].factor != 1
      	set move.extruders[0].factor = 1
      i usually get the following error:
      Error: expected '=' in line 2 of Reset Speed and extrusion factor.txt
      I already experimented with braces and different order - but i didnt get it to work.
      Thank you in advance!
      • chrishammundefined
        chrishamm administrators @DavidG_68kg_PLA
        @DavidG_68kg_PLA You cannot write to the object model directly using set, it only supports local or global variables. Use M221 D0 S100 or M221 D0 S{myFactor * 100} to set the extrusion factor.
        Duet software engineer
        DavidG_68kg_PLAundefined 1 Reply Last reply Reply Quote 1
          DavidG_68kg_PLA @chrishamm
          @chrishamm thanks, chris!
          • dc42undefined dc42 marked this topic as a question
