    Independant Dual Z Axis settings
    Firmware installation
    • pcsentinel
      pcsentinel last edited by
      Hi, can someone clarify if you need to extend the motor settings in config.g if you are using independent z axis motors?
      i.e. I have connected my Z motors to the Duex5 Drives 8 and 9
      set drive assignments as below
      M584 X0 Y1 Z8:9 E3:4; assign drives to axis
      but should the max speed settings included doubles for Z i.e. should these read
      M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping without interpolation
      M566 X600 Y600 Z100 E200:200 ; Set maximum instantaneous speed changes (mm/min) bumped up extruder settings
      or
      M350 X16 Y16 Z16:16 E16:16 I1 ; Configure microstepping without interpolation
      M566 X600 Y600 Z100:100 E200:200 ; Set maximum instantaneous speed changes (mm/min) bumped up extruder settings
      or doesn't it matter
      thanks
        The M350 and M566 commands need only specify one Z value, which will be applied to both Z motors. Similarly for M92, M201 and M203.
        • pcsentinel
          Thanks DC
