Prusa Style Filament AutoLoad macro
Thought I'd share my Prusa style autoload macro (firmware => 3.5.0) for others to use or improve. Please feel free to add your suggestions! This assumes you have a filament sensor.
EDIT: I've updated the load.g code to make it a little more smart.
daemon.g
; Monitor the Filament Sensor to see if it's loaded if {sensors.filamentMonitors[0].status = "noFilament"} M98 P"0:/macros/load.g" load.g
; Filament AutoLoad Macro for RepRapFirmware ; While waiting for the user to load filament, check the filament sensor while {sensors.filamentMonitors[0].status = "noFilament"} M117 "Please load filament." ; Read filament sensor and if filment is present, continue the load process if {sensors.filamentMonitors[0].status = "ok"} ; Ask user what type of filament is loaded M291 S4 T0 P"Select Filament Type" R"Filament Type" K{"PLA","PETG","ABS","TPU","Nylon"} ; Set the temperature based on the filament type if {input == 0} G10 S200 ; Set temperature for PLA elif {input == 1} G10 S235 ; Set temperature for PETG elif {input == 2} G10 S240 ; Set temperature for ABS elif {input == 3} G10 S220 ; Set temperature for TPU elif {input == 4} G10 S250 ; Set temperature for Nylon M116 ; Wait for the temperatures to be reached M83 ; Extruder to relative mode ; Move E till filament is grabbed by gears G1 E15 F120 ; Extrude 15mm of filament at a speed of 120mm/min ; Ask user if filament was grabbed by gears. If not, grab a little more filament var loaded = false while {var.loaded = false} M291 S4 T0 P"Filament Loaded?" R"Filament Loaded?" K{"Continue","Try Again"} if {input == 1} ; Try again set var.loaded = false G1 E15 F120 ; Extrude 15mm of filament at a speed of 120mm/min continue elif {input == 0} ; Continue set var.loaded = true break if {var.loaded == true} ; Change the extruded amount depending on the size of your hotend setup. G1 E80 F240 ; Extrude 80mm of filament at a speed of 240mm/min. ; Ask user if filament is extruding properly var extruded = false while {var.extruded = false} M291 S4 T0 P"Filament Extruding?" R"Did filament come out?" K{"No","Yes"} if {input == 0} ; No set var.extruded = false G1 E15 F240 ; Extrude 15mm more of filament at a speed of 240mm/min continue elif {input == 1} ; Yes set var.extruded = true break ; Set the extruder position to 0 G92 E0 M104 S0 ; set tool temp to 0 -
