    Possible bug (RRF3.5.1): M208 throws error when used with array
    Gcode meta commands
    • NeoDueundefined
      NeoDue
      In order to make axis limits tool-dependent (see here), i wanted to define the X and U limits on my IDEX printer as follows:
      ; config.g
      if !exists(global.X_Limit)
          global X_Limit = {-175.5,151}       ; X limits
      if !exists(global.U_Limit)
          global U_Limit = {-151,175.5}       ; U limits
      M208 X{global.X_Limit[0]}:{global.X_Limit[1]} Y-101:101 Z0:209 U{global.U_Limit[0]}:{global.U_Limit[1]}
      That resulted in the error "M208: U axis maximum must be greater than minimum".
      The same happens if I define only the U or the X values to shorten the command.
      If I use the old separate notation however...
      M208 S0 X{global.X_Limit[1]} Y101 Z209 U{global.U_Limit[1]}
      M208 S1 X{global.X_Limit[0]} Y-101 Z0 U{global.U_Limit[0]}
      ...it works as it should, except that the variables are not replaced by their values in the console output.
      Can anyone confirm this behaviour?
        dc42 administrators @NeoDue
        @NeoDue There has been a change to the way that expressions are used as parameters with array type in GCode commands. Now the entire parameter must be either a colon-separated list of literal values, or an expression of array type. Try this:
        M208 X{global.X_Limit[0], global.X_Limit[1]} Y-101:101 Z0:209 U{global.U_Limit[0], global.U_Limit[1]}
        NeoDueundefined 1 Reply Last reply Reply Quote 1
        • NeoDueundefined
          NeoDue @dc42
          @dc42 Thanks, that one works as intended 🙂
          • NeoDueundefined NeoDue marked this topic as a question
          • NeoDueundefined NeoDue has marked this topic as solved
            @NeoDue I have now added this change to the upgrade notes at https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x#reprapfirmware-351-stable-changes-since-346.
