    documentation fix re developing plugins
    Plugins for DWC and DSF
    1
    1
    153
    • achrnundefined
      achrn
      https://github.com/Duet3D/DuetWebControl/wiki/Third-Party-Plugins#creating-a-plugin says "There are two files which are mandatory for a DWC plugin: plugin.json index.js"
      https://github.com/Duet3D/DuetWebControl/wiki/Third-Party-Plugins#indexjs says "The file index.js is the main entry point of your plugin and it is executed as soon as your plugin is loaded. ... The EndstopsPlugin is another good starting point."
      However, as far as I can see, the endstops plugin at https://github.com/Duet3D/DSF-Plugins/releases/tag/v3.4.0 does not contain an index.js, which suggests the general statement about teh file being mandatory is incorrect, and the specific statement about consulting that plugin should probably refer to a different one?
