3.5.1: Duet2+SBC firmware crash-loops
I am running an Duet2 Wifi with the SPI adapter to connect an SBC.
I tried upgrading from a working 3.4.6 setup to 3.5.1 using
apt upgrade
. DCS, DWC, etc. all upgraded nicely. Thereprapfirmware
package also updated and flashed the new firmware as expected, however, then the SPI connection to the Duet2 failed to re-establish.After some troubleshooting, it turns out, that installing the
Duet2Firmware_SBC.bin
for 3.5.1 on my Duet board, it will simply crash loop the board.DCS fails to connect with:
May 04 16:27:56 voron DuetControlServer[952]: Duet Control Server v3.5.1 May 04 16:27:56 voron DuetControlServer[952]: Written by Christian Hammacher for Duet3D May 04 16:27:56 voron DuetControlServer[952]: Licensed under the terms of the GNU Public License Version 3 May 04 16:27:57 voron DuetControlServer[952]: [info] Settings loaded May 04 16:27:58 voron DuetControlServer[952]: [info] Environment initialized May 04 16:27:58 voron DuetControlServer[952]: [warn] Restarting full transfer because a bad header format code was received (0xff) May 04 16:27:58 voron DuetControlServer[952]: [fatal] Could not connect to Duet: Timeout while waiting for transfer ready pin May 04 16:27:58 voron systemd[1]: duetcontrolserver.service: Main process exited, code=exited, status=69/UNAVAILABLE May 04 16:27:58 voron systemd[1]: duetcontrolserver.service: Failed with result 'exit-code'. May 04 16:27:58 voron systemd[1]: Failed to start duetcontrolserver.service - Duet Control Server. May 04 16:27:58 voron systemd[1]: duetcontrolserver.service: Consumed 2.409s CPU time. Flashing back 3.4.6 via USB and
bossac
is recovering the device.
When working with 3.4.6 I can use USB-serial to connect to the Duet2 directly and get this output:<CONNECTED> RepRapFirmware for Duet 2 SBC version 3.4.6 <DISCONNECTED> After bossac-flashing the 3.5.1 binary, the USB-serial port vanishes and re-appears about once per second. This matches the LED next to the USB port on the Duet2 briefly flashing red. I can't capture any debug output on this USB-serial console as it disappears before I can connect.
I noticed that the 3.5.1 binary is using 927 flash pages (474572 bytes), while the 3.4.6 uses only 877 pages (448900 bytes).
Is Duet2 + SBC over SPI still a supported setup?
@resam I can confirm this problem and we're working on a fix. For the moment, you can use the 3.5.0-rc.4 2SBC build which does not suffer from this problem.
@resam I've updated the reprapfirmware package again with a working 2SBC build of RRF 3.5.1. A regular system update should work correctly now.
@chrishamm Thanks! I installed the new package, and it updated fine - seems to work now!
