Solved MCU Temperature duet wifi
MCU Temperatura Volevo sapere come accendere la ventola quando MCU Temperatura supera i 40° perche adesso e sempre accesa18/05/2024, 19:57:43 m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.2 (2022-09-13 15:11:16) running on Duet WiFi 1.02 or later + DueX2v0.11
Board ID: 0JD2M-9F8TA-GJ4TD-6J9F2-3S06P-KQNA7
Used output buffers: 1 of 26 (24 max)
Static ram: 23860
Dynamic ram: 77028 of which 0 recycled
Never used RAM 11192, free system stack 170 words
Tasks: NETWORK(notifyWait,26.2%,242) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) DUEX(notifyWait,0.0%,24) MAIN(running,73.6%,410) IDLE(ready,0.2%,30), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:07:53 ago, cause: software
Last software reset at 2024-05-18 19:49, reason: User, GCodes spinning, available RAM 11192, slot 2
Error status: 0x00
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 32.4, current 33.7, max 34.0
Supply voltage: min 25.5, current 25.7, max 26.1, under voltage events: 0, over voltage events: 0, power good: yes
Events: 0 queued, 0 completed
Driver 0: standstill, SG min n/a
Driver 1: standstill, SG min n/a
Driver 2: standstill, SG min n/a
Driver 3: standstill, SG min n/a
Driver 4: standstill, SG min n/a
Driver 5: standstill, SG min n/a
Driver 6: standstill, SG min n/a
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Date/time: 2024-05-18 19:57:40
Slowest loop: 21.07ms; fastest: 0.19ms
=== Storage ===
Free file entries: 10
SD card longest read time 7.7ms, write time 0.0ms, max retries 0
DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== Filament sensors ===
Extruder 0 sensor: ok
Extruder 1 sensor: ok
=== DueX ===
Read count 1, 0.13 reads/min
=== Network ===
Slowest loop: 30.57ms; fastest: 0.00ms
HTTP sessions: 1 of 8
= WiFi =
Network state is active
WiFi firmware version 1.27
WiFi MAC address e8:68:e7:7f:6d:82
WiFi Vcc 3.46, reset reason Power up
WiFi flash size 2097152, free heap 24760
WiFi IP address 192.168.1.15
WiFi signal strength -60dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
Socket states: 0 0 0 0 0 0 0 0 -
undefined paolozampini1973 marked this topic as a question
undefined paolozampini1973 has marked this topic as solved
@paolozampini1973 said in MCU Temperature duet wifi:
Please share your config.g to show how you have the fan and temp sensor configured currently.
