    Unexpected error with # and ternary operator
    Gcode meta commands
    • DonStaufferundefined
      DonStauffer
      I've found that to get the size of an array which is element of an array, I have to parenthesize the array expression. That's no problem, and this displays "C=2" as expected:
      var A = {{1,2}, {3,4}}
      ;var B = 0
      var C = (exists(var.B) ? var.B : #(var.A[0]))
      echo "C="^var.C
      However, remove the semicolon so that B is defined, and it seems like you should see "C=0", but instead you get:
      Error: in file macro line 3 column 45: meta command: expected object model value or string after '#
      (Incidentally missing the closing apostrophe; also, it seems like it should say "expected object model value, string, or array expression after '#'".)
      Parenthesizing the # expression doesn't help. It seems to be a parsing error. Possibly failing to recognize the : as part of the ternary operator under some circumstances.
      DonStaufferundefined 1 Reply Last reply Reply Quote 0
        DonStauffer @DonStauffer
        @DonStauffer Obvious workaround :
        var B = 0
        var D = #(var.A[0])
        var C = exists(var.B) ? var.B : var.D)
        echo "C="^var.C
        dc42undefined 2 Replies Last reply Reply Quote 0
          dc42 administrators @DonStauffer
          @DonStauffer which firmware version are you using, and are you using standalone mode or attached SBC? I just tested this, which is the same as your example with the brackets after # removed and it works for me:
          ;var B = 0
          var C = (exists(var.B) ? var.B : #var.A[0])
          echo "C="^var.C
          If I remove the semicolon from the second line then it also works. I am running 3.6.0-alpha.1 in standalone mode. The expression parsing code has not changed since 3.5.2. Maybe you are running in SBC mode?
            @DonStauffer I have now reproduced this and created https://github.com/Duet3D/RepRapFirmware/issues/1020 and https://github.com/Duet3D/RepRapFirmware/issues/1021.
            dc42 created this issue in Duet3D/RepRapFirmware
            closed Incorrect processing of # operator when operand is an element of an array of arrays #1020
            closed Parsing error when using ternary operator #1021
