    I ma not able to write or edit on DUET 3 3.5.2 firmware
    Using Duet Controllers
    1
    • martin7404undefined
      martin7404
      After 2 weeks pause I powered my Duet controled printer with Duet 3 board and I am not able to uplad any file
      get this kind of error
      I think it is SD card
      what is the less painfull way to get it up back to life
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.5.2 (2024-06-11 17:13:58) running on Duet 3 MB6HC v1.01 (standalone mode)
      Board ID: 08DJM-9P63L-DJMSS-6JKDA-3S86L-1BDB9
      Used output buffers: 3 of 40 (31 max)
      Static ram: 155360
      Dynamic ram: 120656 of which 488 recycled
      Never used RAM 69488, free system stack 202 words
      Tasks: NETWORK(1,ready,38.0%,155) ETHERNET(5,nWait 7,0.1%,318) HEAT(3,nWait 6,0.0%,323) Move(4,nWait 6,0.0%,335) CanReceiv(6,nWait 1,0.0%,794) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,348) TMC(4,nWait 6,9.3%,53) MAIN(1,running,51.9%,103) IDLE(0,ready,0.7%,29), total 100.0%
      Owned mutexes:
      Last reset 00:28:20 ago, cause: software
      Last software reset at 2024-07-29 21:32, reason: User, Gcodes spinning, available RAM 69340, slot 1
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU temperature: min 29.5, current 29.7, max 30.6
      Supply voltage: min 24.1, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min n/a, mspos 4, reads 27541, writes 0 timeouts 0
      Driver 1: standstill, SG min n/a, mspos 4, reads 27541, writes 0 timeouts 0
      Driver 2: standstill, SG min n/a, mspos 8, reads 27541, writes 0 timeouts 0
      Driver 3: standstill, SG min n/a, mspos 8, reads 27541, writes 0 timeouts 0
      Driver 4: standstill, SG min n/a, mspos 8, reads 27542, writes 0 timeouts 0
      Driver 5: standstill, SG min n/a, mspos 8, reads 27542, writes 0 timeouts 0
      Date/time: 2024-07-29 22:00:33
      Slowest loop: 536.11ms; fastest: 0.07ms
      === Storage ===
      Free file entries: 20
      SD card 0 detected, interface speed: 25.0MBytes/sec
      SD card longest read time 42.1ms, write time 9.3ms, max retries 0
      DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
      no step interrupt scheduled
      Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
      === DDARing 0 ===
      === DDARing 1 ===
      Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      File2 is idle in state(s) 0
      Queue2 is idle in state(s) 0
      Q0 segments left 0, axes/extruders owned 0x0000000
      Code queue 0 is empty
      Code queue 1 is empty
      === Filament sensors ===
      check 0 clear 9325857
      Extruder 0 sensor: ok
      === CAN ===
      Messages queued 2726, received 6055, lost 0, errs 0, boc 0
      Longest wait 0ms for reply type 0, peak Tx sync delay 6, free buffers 50 (min 50), ts 1514/1514/0
      Tx timeouts 0,0,0,0,0,0
      === Network ===
      Slowest loop: 557.27ms; fastest: 0.03ms
      Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 1 of 8
      = Ethernet =
      Interface state: active
      Error counts: 0 0 0 0 0 0
      Socket states: 5 2 2 2 2 0 0 0
      === Multicast handler ===
      Responder is inactive, messages received 0, responses 0
      M122 P104
      Testing SD card write speed...
      Error: Failed to write to file, error code 1. Card may be full.
      Error: Failed to write to file. Card may be full.
      Error: Failed to flush data to file. Card may be full.
      Error: M122: Failed to write to timing file
      Muldex IDEX Duet2+Duex5
      Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
      Sapphire Pro with Duet2, with closed-loop motors
      custom high temp E3D tool changer with Duet2+Duex
        martin7404
        Fixed it . It was 2 years old SD card. Good quality card. Formated a new one and created new structure witht the current firmware and config. back to printing
        • dc42undefined dc42 marked this topic as a question
        • chrishammundefined chrishamm has marked this topic as solved
