    Sensorless homing question ..
    Config Tool
    • timls3674undefined
      timls3674
      On the config tool if I use the version 3.4 and want to select sensorless homing for end stops it specifically states a option “sensorless” as a option but if I use the version 3.5 version which I want to use I see no option that specifically says sensorless for end stops and I would like to know how to choose sensorless homing .the options I have from drop down menu are switch, probe #0, single motor load detection, multiple motor load detection, and none.
      Would it be single motor load detection? Not sure if someone could please help out
      Thanks
      Tim
        Phaedrux Moderator @timls3674
        @timls3674 said in Sensorless homing question ..:
        Sensorless is using the motor driver load detection to detect a stall.
        Whether it's single or multiple motor will depend on your setup. An example of multiple would be a multiple motor Z axis setup, or an X axis with two motors.
