    Crash when creating a variable from an Object Model array
    Firmware developers
    • leoneundefined
      leone
      Hi all,
      I'm getting software crashes when I try to set variables from certain Object Model items:
      echo state.restorePoints[0].coords     --> OK
      var a = state.restorePoints[0].coords  --> OK
      echo state.restorePoints[1].coords     --> OK
      var b = state.restorePoints[1].coords  --> KO
      var c = state.restorePoints[1].toolNumber  --> OK
      it crashes also with var z = tools[1].extruders.
      It seems like the problem is when copying the array field from the second element of an array of objects.
      I'm currently using RRF 3.5.2, but I tried also 3.5.0 and the issue is the same.
      Can you replicate the issue or am I missing something?
      Thanks
        dc42 administrators @leone
        @leone thanks, I can replicate that. I've created https://github.com/Duet3D/RepRapFirmware/issues/1029.
        dc42 created this issue in Duet3D/RepRapFirmware
        closed Crash when creating a variable from an Object Model array #1029
        leoneundefined 1 Reply Last reply Reply Quote 1
        • leoneundefined
          leone @dc42
          @dc42 thanks!
