    Completely unreasonable measured per revolution?
    Filament Monitor
    1
    • janjohundefined
      janjoh
      All of a sudden my sensor seem to have lost its little electronic mind.
      A full poweroff does not fix it.
      Running 3.5.2
      ; Filament sensor
      M591 P3 C"e0_stop" S1 R20:200 L24.8 E6.0 D0
      2024-08-06, 15:49:53	M591 D0
      Duet3D magnetic filament monitor v3 on pin e0stop, disabled, 24.80mm/rev, allow 20% to 200%, check printing moves every 6.0mm, mag 132 agc 86, measured 11604.83mm/rev, min -188% max 34941% over 3059.9mm
      2024-08-06, 15:49:52	M591 D0
      2024-08-06, 15:49:51	M591 D0
      2024-08-06, 15:49:49	M591 D0
      Duet3D magnetic filament monitor v3 on pin e0stop, disabled, 24.80mm/rev, allow 20% to 200%, check printing moves every 6.0mm, mag 132 agc 86, measured 11578.66mm/rev, min -188% max 34862% over 3053.0mm
      2024-08-06, 15:49:47	M591 D0
      2024-08-06, 15:49:32	M591 D0
      Duet3D magnetic filament monitor v3 on pin e0stop, disabled, 24.80mm/rev, allow 20% to 200%, check printing moves every 6.0mm, mag 132 agc 86, measured 11529.47mm/rev, min -187% max 34714% over 3040.0mm
      • janjohundefined
        janjoh
        It seem to be a TPU thing. WHen loading Ninjaflex, it seem to just not grip the filament enough, leading to these unreasonable values.
        Well, I guess I can live with that..
        • janjohundefined
          janjoh
          Hm.. I suppose that IF the magnet rotated verrrrrry slowly due to being obstructed or similar, this could happen... I suppose a teardown is in order.
          • janjohundefined janjoh referenced this topic
          • janjohundefined
            janjoh
            • janjohundefined janjoh has marked this topic as solved
