    Bed and Hotend Temperatur
    Duet Web Control
    temperature
    • Buccaneerundefined
      Buccaneer
      Hello
      I am using orca and in the start code I use m109 and m190 for the temp. But I need to write the temp I want into the start code also. That’s not what I know. I didn’t find a way how web control takes the value I put in the slicer.
      Any idea for me.
        I'm not super familiar with Orca slicer, but normally in if you leave out the temperature commands from your start gcode, the slicer will insert it's own using the temperature you've set in the settings.
