    Auto squaring workbee Y-axis on Duet3D 2 v3.3.0
    CNC
    • facardiundefined
      facardi
      Hello. I installed a second Y home switch on my workbee. I use this firmware v3.3.0 ->
      https://ooznest.co.uk/2021/11/15/workbee-control-v3-3-0-is-out-g-code-viewer-included/
      config.g
      ; Configuration file for Duet
      ; WorkBee Firmware Version 1.1
      global systemSettingsVersion={1.2}
      ; Configuration files
      M98 P"config-network.g"
      M98 P"config-drives.g"
      M98 P"config-axes.g"
      M98 P"config-axes-limits.g"
      M98 P"config-axes-calibration.g"
      M98 P"config-axes-endstops.g"
      M98 P"config-probe.g"
      M98 P"config-spindle.g"
      M98 P"config-laser.g"
      ; Other Settings
      M453 ; Put the machine into CNC Modes
      G90 ; Set absolute coordinates
      M140 H-1 ; Disable heated bed
      M564 S1 H1 ; Disable jog commands when not homed
      M911 S21.0 R23 P"G91 G1 Z3 F1000" ; Configure power loss resume
      ; User Configuration files
      M98 P"config-user-settings.g"
      M501 ; Load Stored Parameters
      config-axes.g
      ; Axes configuration executed by config.g
      M584 X0 Y1 Z2 U3 ; Apply drive mapping to axes
      M584 P3
      M906 X2400 Y2400 Z2400 U2400 I100 ; Set motor currents (mA)
      M92 X400 Y400 Z400 U400 ; Set steps per mm
      M350 X16 Y16 Z16 U16 I1 ; Configure microstepping
      M203 X2500 Y2500 Z2500 U2500 ; Set maximum speeds (mm/min)
      M201 X150 Y150 Z150 U150 ; Set accelerations (mm/s^2)
      M566 X500 Y500 Z500 U500 ; Set maximum instantaneous speed changes (mm/min)
      M669 K0 X1:0:0:0 Y0:1:0:1 Z0:0:1:0
      homey.g
      ; homey.g
      ; called to home the Y axis
      G91 ; relative positioning
      G21 ; Set units to mm
      G1 H1 Z{move.axes[2].max*2} F900 ; move quickly to Z axis endstop and stop there (first pass)
      G1 H1 Y{move.axes[1].max*2} F2400 ; move quickly to Y axis endstops and stop there (first pass)
      G92 Y{move.axes[1].max} Z{move.axes[2].max} ; Set Home Position
      G1 Y-3 Z-3 F2400 ; go back a few mm
      G1 H1 Y{move.axes[1].max*2} F300 ; move slowly to Y axis endstops once more (second pass)
      G1 H1 Z{move.axes[2].max*2} F300 ; move slowly to Z axis endstop once more (second pass)
      G90 ; absolute positioning
      What can I change to have auto squaring of the Y axis using 2 motors ?
      Thank you.
      I followed a guide from the wiki I know I need to start with :
      M584 X0 Y1:3 Z2 U3
        You can follow this guide to setup double axis motor homing.
        https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_auto_levelling#axis-levelling-using-endstops
        If you are unable to adjust the endstop positions to make them even, and need to apply an offset to one of the motors, you would need to modify your homing routine. You could use the combined motor axis to home initially, and then split the axis and apply your offset to one of the motors with a G1 move and then recombine the axis again.
        • facardiundefined
          facardi
          config-axes-endstops.g (STOCK)
          ; Endstop configuration executed by config.g
          M574 X2 P"xstop" S1 ; Set active low X endstop
          M574 Y2 P"ystop" S1 ; Set active low Y endstop
          M574 Z2 P"zstop" S1 ; Set active low Z endstop
          I modified it to look like this :
          M574 Y2 P"ystop+e0stop" S1 ; Set active low Y endstop
          Ok now both limit switches trigger the Y end stop ! Thank you.
          Can you help me with the homing gcode ? I don't know how to modify it.
          I know how to split the axes :
          M584 Y1 U3
          M584 P4
          droftartsundefined tierodundefined 2 Replies Last reply Reply Quote 0
            droftarts administrators @facardi
            @facardi You're using RRF 3.x firmware, so you don't need to split the axes. All you needed to do was add the extra endstop pin to the M574 command.
            Or do you need to split the axes to correct for the endstop position? Generally it is easier to have an adjustable endstop on one side, to account for the endstop position. If you still want to adjust the axes, probably the easiest thing to do is to add a U axis adjustment after homing. Ideally move the Y axis (so both Y motors) away from the endstops, then send a relative movement command of the U axis to account for the skew in the X axis, eg:
            G1 Y-3 F300 ; move axes away from endstops
            G1 U1.0 F300 ; adjust Y2/U axis position
            Adjust the U value as necessary. Add the line to homeall.g and homey.g. I don't think you need to split the axes to do this, because you don't need to home this axis.
            Did you add U axis limits to 'config-axes-limits.g'?
            • tierodundefined
              tierod @facardi
              @facardi
              as a side note, using a end stop for each motor, i ran into an issue while homing. i had a faulty endstop one time (shorted) and because i use nema 32 steppers the one side drove so hard i bent my y axis. the guys here helped me by writing a script that checks for shorts before it homes. it triggers a error message and stops homing routine. it works great! i don’t know how to give a link but just look for “dual axis woes”
