is it possible to send GCode via python?
I am using a "duet3 mb6hc (3.4.5)" to build a hangprinter Ver4. https://hangprinter.org/doc/v4/
I tried to send GCode commands following this github wiki: https://github.com/Duet3D/RepRapFirmware/wiki/HTTP-requests
But I haven't received a response. I know that the Python code is okay because I have used the same technique in different Duet3 hanging printer builds.
Can anyone help me? How can I send GCODE commands programmatically with my current setup?" to build
@andreasMch In standalone mode you must query
rr_reply
as well if you need the G-code response. To know when a new response is available, you should monitorseqs
fromrr_model
as documented in the documentation article.
